CEN Racing This forum is to discuss all CEN Racing products.
Roto Tech starter
Old 10-15-2006 | 04:27 PM
Default Roto Tech starter
Will the roto tech starter from cen work on the Magnum NX? My pull cord broke. Is there a good starter box that will work with the magnum nx
Old 10-15-2006 | 05:13 PM
Default RE: Roto Tech starter
i dont think there is a roto start but the tiger drive will work. starter box too, just check with your local hobby shop for the right applcation. take your car there and they should be able to get you one that works
Old 10-15-2006 | 05:29 PM
Yes, the roto tech starter will work, I use one on mine. You just have to take the body off to start or driil a hole in hood for easy acces so you dont have to remove the body. Make sure to grease the gears before installing it on the motor.
Old 10-15-2006 | 05:35 PM
you have a cen magnum and it works on it? (just makeing sure)
