ct5s information
hey all, this is a continuation to my other post.
can anyone send me some pcitures or a manual for the ct5's and also a manual or info on how to setup and install the radio gear for it.
and i will need some info or advice on how to properly run-in and setup the car for best perfomance and usage.
i have runin a r/c car be4(my old thunder tigger ssr), but alot of people say you must run-in and setup this car right to get it up to the claimed 117km/h, or 73.4 mph for you yanks.
im using 20%nitro fuel with 20%oil, form hotstuff fuels(prob best fuel in aus right now).
and what is the best and highest nitro% this car can run?
any other info i wil need will be great, thanks
Banned
total, i believe you can go to www.cenracing.com and download the manual.
the rest you will be beter suited to find a local nitro guru, hands on is far better than read it here first type tuning. you ll learn FAR MORE with someone in your area to give hands on.
hth
Timmahh
hth
Timmahh
thanks timmahh
i had a chat to one of my couz's mates and he said the rollbar/carry handle is an extra, as is the aluminium exhaust. but i got a 150 buck(aud) exhaust from japan, i didnt pay for it, some one had it lying around and i took it(duno if they knew i did).
with the wheel, i fixed it all up, its a little angled in, and cambered.
but before it was way off, the wheel was pointing in more than it should. trust me it was bad, but its all good now.
im gona run it in today, with 20%nitro, and 20%oil in it. local hobby stores said to run it in on 16 or 20% nitro.
do you know what % these beasts go up to?
and i'll definately be ordering the rollbar and tuned pipe soon.
and does this 'extra' gear thingo come with the car, or does it have to be bought(can u send me a pic of it, im still a little confused bout the whole thing.)
all i know is that you can adjust the tightness of the belt running from the centre to the front diff.
i have mine set fairly tight, but not too tight.
yeah i went to the cenracing site as soon as i made the post.
they got alot of info i needed. the manual helped alot when i had to setup the radio gear and install it.
i'll post some pics off it and some parts that have been modded(problem areas). i like to do alot of hands on stuff, so i checked how things work and what can be adjusted and what cant, and what to touch and what not too. ive learnt alot bout it in a few hrs.
