CEN Racing This forum is to discuss all CEN Racing products.
CEN simularites
Old 12-03-2006 | 02:57 PM
mr.edzadventure's Avatar
Default CEN simularites
I don't post a whole lot but I read a lot on this tread. So here is something I found interesting let me know what you think. I picked up an (GASP)! H.P.I. MT2 real cheap last month. The rear back plate of the engine was drilled full of holes to accommodate an power drill starter that was the wrong kind. Well I had an extra pull starter and backplate off of a NT.16 I put it on the H.P.I. .18ss engine it fits perfectly not even off 1 mm. so I started to look at other things . The screws look similar, the anodizing color of the chassis look alike. Some of the plastic parts look like they could be made together to. I wonder if the H.P.I. and CEN fun factors are made by some subcontractor who makes parts for both.
Old 12-04-2006 | 10:09 PM
Default RE: CEN simularites
Last I heard, CEN used to OEM for HPI a while back...
I doubt there going through the same subcontractors....But it is likely since both cars are built in Taiwan, both companies are using the same vendor for screws and other small misc parts.
Old 12-05-2006 | 07:14 PM
I was still surprised that the cen back plate worked on the hpi engine. I did it she kicks and grins to see if it was close and (WAALLLA) it fit. maybe the engines are subbed out. The bushings are the same size in the back plate and the screw holes line up perfect. The shape of the backplates are the same just different screw holes for the hpi pullstart. . i wonder if some one like Enaya or another Taiwan CO. is making engines for them under there specs.
Old 12-05-2006 | 09:42 PM
Banned
NO!!!they just happen 2 b the same
Old 12-06-2006 | 07:33 PM
The same ??? engine. The same factory, the same country The engine block looks different.
Old 12-06-2006 | 08:22 PM
Enya is a japanese engine company. And they make darn good engines at that too. Enyas are known to last forever and ever in the RC airplane world.
I have an Enya R155 4 stroke engine. That thing is machined so nice and I am tempted to use it in a four stroke monster truck project.
Thumpers!!!
Old 12-06-2006 | 09:38 PM
Banned
ORIGINAL: mr.edzadventure
dont try and get all smart with me you ask a ??? and i told you ....i guest i have to use every detail so NO!!!! there not the same at all just the pull starter happens to be the same..........newbes these days....[:-]
Old 12-07-2006 | 09:07 PM
I wasn't sure where Enya was located I thought they were Taiwanese CO. I have heard nothing but good things about there engines. I would consider them for an airplane one of these days.
Old 12-08-2006 | 04:09 PM
Our designs are all original CEN has been a OEM for over twenty years... it is posible that they coppied some of our designs...
