NT 16
From fully screwed in - try between 2.5 and 3.5 full turns out on the high speed needle, and on the low speed, you want the screw head flush with its surround. Thats the factory settings if I remember rightly. Good luck.
AB, CANADA
According to CEN:
Top end: 3 – 3 ½ turns out
Bottom end: Flush – 1 turn in from flush
Idle gap: 1mm
Recommended engine temp: 210 – 230 degrees Fahrenheit
Scroll to the NT 16 and click tuning guide. http://www.cenracing.com/engines.html
Idle gap: 1mm
