Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > CEN Racing
 Genesis front/rear bulkhead assembles. >
CEN Racing This forum is to discuss all CEN Racing products.
Old 01-11-2007 | 05:10 PM
Default Genesis front/rear bulkhead assembles.
Hello everyone.
Please could someone give me some help.
I have a CEN genesis which i am currently installing nemesis aluminium cased front/rear diffs. Please could someone tell me which holes (upper/lower) to put the plugs in, on the front and rear bulkheads (I have the nemesis bulkheads as well). The genesis manual does not specify.
THANKS
Kris.
Old 01-11-2007 | 07:59 PM
CEN Racing's Avatar
Default RE: Genesis front/rear bulkhead assembles.
Kris- if you are reffering to the brace- that would be upper holes.
Old 01-13-2007 | 07:52 AM
Hello,
Thanks for the reply. However i'm not referring to the braces. I'm referring to the plugs on the bulkhead assembly.
I have downloaded the nemesis manual but i think there is a printing error in section 5 (05-02 front bulhead). In this section it says to put the plugs in the upper holes on the bulkhead but the diagram shows them going into the lower holes.
Its the same for section 05-03 rear bulkhead. In this section it says to put the plugs into the lower holes on the bulkhead but the diagram has them pictured going into the upper holes.
Can you tell me if the text or the diagrams are correct.
THANKS, Kris.
Old 01-13-2007 | 12:21 PM
The Real Dogman's Avatar
Hey Chris, You are referring to the holes that rotate the diff housing up and down between the bulkheads..On the rear the plugs go in the top hole to rotate the pinion of the diff down because the rear suspesion angle is not as great as the front..Now the front plugs will go into the bottom hole to rotate the diff pinion up due to the front suspension kick-up. these plugs are designed to keep the drive shaft to diff pinion angle as straight as possible...
I hope this helps-Have fun!!
Old 01-14-2007 | 04:24 PM
Hello 'The Real Dogman', thanks for replying.
That is exactly what i needed to know. Thanks for the explanation as well.
I can finish rebuilding my gen and get bashing.
CHEERS MATE.
Kris.
Genesis: Quite modded (full GPM aluminium, Carbon side plates, nova head, etc).
Lightning 2 buggy: Fully modded
