front dogbones keep poping out
I have matrix tr arena and my front dogbones keep poping out !! when i slam they pop. I have noticed when I push the A arm all the way up I can almost pop them out by hand . Please help I have rtr .
thanks,
ICC
thanks,
ICC
NY
i'm wondering if your camber is really misajusted. do your wheels lean outward a good amount? I'd tighten up the upper arm a bit and should solve the problem
I did try ajusting the camber but when the A arm is at its highest point there is just to much play at bottom . The cup drives off the front diff have taken a beating . If I need to post pics i can?
thanks,
ICC
thanks,
ICC
I Think by moving the shock mount in front on the top to the number two hole bottom row or bottom row 1st hole(outside hole) and moving the bottom shock tower mount to the 1st inside hole on A arm .This might help !!!!!!! Also back shocks top mount moved to the middle bottom row hole and the middle hole A arm rear>Thank
ICC
sorry if this makes no sense!
ICC
