MT2 Grub screw
MD
Hey guys
I cant find the part number for the grub screw between the 2 spur gears. Anyone have the part number?
Correct me if I am wrong, but this controls the shift points right?
Tinybaum
Tinybaum
RI
I went on the Cen website and downloaded the exploded view. they dont give a part number for the mt2, but if it's the same as the mt spec 3 then it is a 3x3mm grub screw. Also check to make sure you dindn't loose the spring and the ball. Theese guys will be able to help you! www.customrccars.com
