CEN Racing This forum is to discuss all CEN Racing products.
after running my gst
Old 06-03-2007 | 02:24 PM
Default after running my gst
hello i just got in from the park running my gst. my question is that i noticed after i toook off the cooling head on top of the engine it was yellow but not like burnt is that normal? i think i blew one of my spark plugs also the coil on it is like all the way up not on the bottom like a new one is. does any one reccomend oiling the tranmission after running? just asking to make this beast last a long time.
Old 06-03-2007 | 03:45 PM
The Real Dogman's Avatar
Default RE: after running my gst
Chris,
Yes the yellow is normal, it is the oil turning color from being burned.
if your glow plug got cooked the coil could do many different things, but if it is gone then look in the cylinder for it, the coil COULD cause the piston to jamb in the cylinder, so be sure you clear it out before you run it again. and no your tranny does not need to be oiled it is one tuff bugger the Genesis series tranny's are.
Glad you had fun..
Old 06-03-2007 | 09:02 PM
ok cool thank you for your help. after the problems with starting it i had now its a nice powerfull truck.
