Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > CEN Racing
 VX .18 heating up.! PLEASE help CEN. >
CEN Racing This forum is to discuss all CEN Racing products.
Old 08-01-2007 | 01:44 AM
Default VX .18 heating up.! PLEASE help CEN.
I have checked needle setting
HSN 2.75 turns from full closed.
LSN flush.
Cen plug #3
The temps on this engine seem to reach much higher than my NT-16 (based on spit test). I dont have a temp gun but the spit sizzles as soon as it hits the cooling head. Do these engines run hotter than NT.16? Should I check anything else??
Old 08-01-2007 | 08:11 AM
Default RE: VX .18 heating up.! PLEASE help CEN.
Brother do I know your pain.The first thing I see is your hsn should be at a maximum of3.5 turns out instead of 2.5,-depending on air quality I have had to run mine 4 turns out.3.5 should be the max,cen also instructs to set hsn at 3.5-2.5 is way to lean.Also I have learned over time that these engines do their best with 15% nitro.You can take this advice to the bank.All About Fun is probably gonna come on here and try to disputue this entire post[:@]but its okay.I have been through a lot with these engines and if I dont know it,I WONT SPEAK IT[:-]Youre right on with the glowplug.Run low nitro content.These motors are famous for heating issues but can do very well if set up right.Good luck
Old 08-01-2007 | 08:54 AM
The Real Dogman's Avatar
Good advice Derrick....
Old 08-01-2007 | 10:28 PM
Thanks for the rundown Derrick.. I will switch to 15%.. Currently on 20% [:'(].
Another thing i was thinking of doing is applying scilicone around the carby to ensure air tightness around that area/?? good idea or not?
