CEN Racing This forum is to discuss all CEN Racing products.
Magnum ??? need some help
Old 09-22-2007 | 05:57 PM
Default Magnum ??? need some help
I had to replace my clutch bell today and when I went to start it back up the wheels are rolling forward when I pull the pullstart. Did I over look something or put some thing on backward. Never had this problem before so not really sure what to look for
Old 09-23-2007 | 01:37 PM
burningpoo's Avatar
Default RE: Magnum ??? need some help
Are your clutch shoes free from the bell? Might be hanging up/got something in there making contact. Not to sure if over tighting would make that happen, never happend to me before.
Old 09-23-2007 | 03:04 PM
Yea i checked the shoes and they and not touching the bell at all. It's weird cause usually the clutchbell will stay idle unless I hit the throttle. But it is engaging while pulling the pull start
Old 09-23-2007 | 06:17 PM
burningpoo's Avatar
Can you hold the flywheel still and turn the bell?
edit:
wow I asked a dumb question...
Old 09-23-2007 | 07:51 PM
If the shoes are on the right way,maybe something to do with your clutch spring.Did you over stretch the spring during assembly?
