GST tune problem
i have some problem when i try to tune the GST's motor.
i saw that after a rectilinear with full trottle gas if i stop the gst and restart...the GST switch off the motor!! why? sometimes it seems to me that the fuel doesn't come to the motor very well.
if i lift the gst and open the gas to the max the motor switch off? i tune the max and the idle but....i don't know.
HELPPP
the fuel is 16%
HELPPP
the fuel is 16%
ofna valve like this: http://www.rcmodelstore.com/catalog/...4445739dc8a084
it isn't ofna but the spirit is the same.
where i must control for air leaks?
ORIGINAL: lambo77
ORIGINAL: nomobux
This http://www3.towerhobbies.com/cgi-bin...?&I=LXEYG3&P=7 Also up the % of nitro to at least 20% Look thru these threads. MUTT ( TRD ) did a bit on the check valve. Check his gallery.
ORIGINAL: lambo77
This http://www3.towerhobbies.com/cgi-bin...?&I=LXEYG3&P=7 seems to me a simple pump. how can it help me for my problem of switch off?
ORIGINAL: lambo77
i didn't found the gallery that you said.
ORIGINAL: nomobux
ORIGINAL: lambo77
ORIGINAL: lambo77
had anyone cutted the fuel tube? how long must be it ?
ORIGINAL: lambo77
my tube is 25 centimeters (9.84252 inches).
isn't it too much long? maybe this is one of some causes of my switching off
ORIGINAL: lambo77
yes, it is!
but a friend's of mine told me that he had to cut a part of mix tube in his revo and all the problems, like mine, resolved.
yes, it is!
Hi to all.....today i took my GST and i tried a glow #3.......well now i haven't suddenly switch off of the motor! so the problem was the glow #5.
i 'm not able to change the second!! why??? i unscrew the screw but...nothing......i'll do it again
