Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > CEN Racing
 Rally wheels/tires for CT5? >
CEN Racing This forum is to discuss all CEN Racing products.
Old 11-06-2007 | 02:46 PM
Default Rally wheels/tires for CT5?
So, I am trying to turn my CT5 into a rally car for dirt and grass. What wheels and tires will work for this? I think the tires have to be 3 inches or under. What would be the best tires for grass and what rims/wheels should I use?
Another question, what would it take to put a .12 engine in a CT5?
Any suggestions as to what I should do to make it a good rally? Thanks.
Old 11-06-2007 | 07:54 PM
Default RE: Rally wheels/tires for CT5?
Please help me out here.
Old 11-07-2007 | 09:58 PM
What wheels and what size hexes will work?
Old 11-08-2007 | 01:47 AM
Bash-m-up's Avatar
My Feedback: (7)
Check out these. [link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXWH12&P=7]CLICK HERE[/link] They should work well with just about any touring car type wheel.
Old 11-08-2007 | 01:51 AM
Bash-m-up's Avatar
My Feedback: (7)
Just go to tower hobbies web site and type in "Rally" and look at the many tires in which you can use. I would assume any touring car type wheel would work as well, I'd say they are all standard hex sizes with tamiya being an exception.
Old 11-08-2007 | 05:29 PM
Will these fit? If not, what wheels would work with them? My goal is to be able to drive on grass with the CT5. Thanks.
Old 11-08-2007 | 06:02 PM
Bash-m-up's Avatar
My Feedback: (7)
The ones I listed should do the trick. You will have to alter your suspension to get the ground clearance though if your wanting to go in and out the grass. Many of the rally cars out there don't trudge through the grass that well because of the clearance issue. But going in the dirt and tidy grass may not be a problem with those tires.
Old 11-08-2007 | 06:06 PM
So will the HPI tires fit on a standard touring wheel? And how do I raise the clearance?
Old 11-08-2007 | 11:56 PM
Bash-m-up's Avatar
My Feedback: (7)
If they are the touring car tires they should fit as well. Most touring car wheels are standard at 26mm wide so any tire that is that width should work. In order to get clearance you will have to make sure the shocks are fully extended.
Old 11-09-2007 | 03:17 AM
CEN Racing's Avatar
Hpi rally tires if you want to stick to traditional rims....
if not check our rally seriers rims and tires- but you would need a wider body
Old 11-09-2007 | 05:08 PM
Sorry. These were the tires I was talking about http://www3.towerhobbies.com/cgi-bin...?&I=LXAHL7&P=7 forgot to post a link LOL
Old 11-09-2007 | 05:57 PM
Bash-m-up's Avatar
My Feedback: (7)
Those tires will require the HPI MT wheels, they would require the proper hexes as well, and are quite a bit larger than that of a touring car. See CEN's post to know exactly what you want.
Old 11-09-2007 | 06:07 PM
Have a part #? I'm not sure which tires you're talking about. When you say, a wider body, do you mean the tires would touch the exhaust or the car body/shell is too thin?
Old 11-10-2007 | 07:39 AM
i would of thought the ct5 with its belt system would last all of 30 seconds on anything but perfectly smooth tarmac. my mates ct 4 doesnt even last that long before a pulley or a belt gives way......and thats in a car park....
Old 11-10-2007 | 12:13 PM
I was sort-of also wondering something else. Will it be bad for my car if I set the EPA throttle adjustment to 120%?
Old 11-10-2007 | 05:43 PM
Bash-m-up's Avatar
My Feedback: (7)
You run a risk of servo failure sooner if you did.
Old 11-11-2007 | 09:37 AM
Hey. I want to do this to. Any thoughts on what to do?
Old 11-14-2007 | 04:23 PM
CEN Racing's Avatar
If you go to a bigger tire a suspension mod will need to be done to compensate the travel needed to function properly.
Anyone got any pics of their rally?
Old 11-15-2007 | 05:36 PM
I would like to see pics!
Old 11-17-2007 | 03:52 PM
I just got a crazy idea. It would be hard.........but worth it. I have once thought of putting my Stampede tires and wheels on my CT5. To do so, I would have to extend the axals. Any idea on how to do so? I have found out that with those tires, the CT5 would have 2 1/4 inches of ground clearance! Is there any way to convert it to a single speed for grass?
Old 11-19-2007 | 05:42 PM
CEN Racing's Avatar
Remember that ground clearance is proportional to Shock travel--- the chassis needs to hit the ground prior to running out of suspension stroke.
Have any of you considered simply picking up one of our NX series rally cars... thos are the best rally cars out there!!!!!!
Here is a link:
http://www.cenracing.com/cars/nx/subaru.html
Old 11-19-2007 | 06:59 PM
I wish I could but I have a $200 budget (at most) and can't spend 300 on a car. Wish I could[]
