CEN Nemesis Help
Hello,
Ive been having some trouble with my CEN Nemesis. I havent run it in months. But today I decided to whip the beast back out and give it a run. For some reason the car will not stay idle. Soon as the glowplug igniter is disconnected from the glow plug it usually dies after a bit. But I can get it going if I keep the revs up. Usually once I let it idle it jumps and trys to take off but I have fixed the throttle on the controller. Once its going it usually doesn't cut but sometimes it does.
Do you guys have any suggestions? Im using 20% in about 30C heat. Do you guys have any rich or lean settings I can use?
