Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > CEN Racing
 question about wheel hex's on genesis >
CEN Racing This forum is to discuss all CEN Racing products.
Old 01-25-2008 | 08:07 PM
Default question about wheel hex's on genesis
Hi, i own one of the first original genesis's. I bought replacement tires for it off ebay to find the rim has a different size wheel hex, I'm guessing these tires must of come off a GST! The hex on the rim is bigger, am i correct to say this is 23mm? And what did my original genesis have 17mm? Also when looking for new wheel adapters I went to cen racing site and i looked up the axle + wheel adapters, i see gs021 for wheel adapters but i also see gs217. Now they look a bit different on the inner opening so i looked up wheel axle's to see if they are the same diameter on the old truck and new truck which i found gs217 and gs245. Anyways to make it less confusing. Will the gs217 wheel adapters fit on my older genesis .46? and if so will the "wheel Nut" off the old genesis fit also?
Old 01-25-2008 | 09:22 PM
The Real Dogman's Avatar
Default RE: question about wheel hex's on genesis
ORIGINAL: paedbo
Yes They will fit and no the old wheelnut will NOT fit, you will eed the 23mm nut too..
[link=http://cgi.ebay.com/new-cen-nemesis-genesis-wheel-hex-bolts-and-drives-23mm_W0QQitemZ110216338514QQihZ001QQcategoryZ44028 QQssPageNameZWDVWQQrdZ1QQcmdZViewItem]This is what you need to make those GST 7.7 wheels fit!![/link]
Old 01-25-2008 | 10:00 PM
ok thanks, i dont care much for the blue nuts though id prefer my chromed ones. I know i might regret this in the future but i decided to try wheel adapter hex's and the tower hobbies tower terror truck has a hex adapter that has a 19mm inner diameter and 23 outter, you just slide it over the existing wheel hex then put the wheel over that, this will allow me to use my chrome wheel nuts. ( i originally thought the .46 genesis was 17 mm hex but after looking at rcuniverse's old review on it i found it to be 19mm). Anyways here's the catalog part in case anyone else wants to try it http://www3.towerhobbies.com/cgi-bin...?&I=LXNFS6&P=7 its made of plastic though so I'll see if they strip out, hopefully not.
Old 01-25-2008 | 10:24 PM
That hex WILL Strip. These trucks put out that much power!! But good luck and be sure to post up your findings for others...
Good luck!!
Old 01-26-2008 | 11:20 AM
nomobux's Avatar
And if you go the Cen 23mm route, oven cleaner will remove the blue fast. Adaptors and nuts are fairly cheap on ebay.
Old 02-01-2008 | 05:27 PM
Ok ill post up my findings so far, The hex adapters for the terror came in, They did not fit, they are a hair too big, they would slide over the 19mm wheel adapter but would not fit into the 23mm gst rims. I took it to work and one of the machinists shaved off a few thousands off each flat on the outter edge till it fit really snug but not loose. The inside adapter fits tight also. I am still running in a new piston and sleeve so i cant really give a full bashing or heavy throttle report yet but they feel like sturdy plastic and with no slop i dont believe theyre going to break, When i checked one of my old wheels and old wheel adapter they do have a tad bit of slop in them which im happy to get rid of with this setup. I will update as i get farther along.
Old 02-02-2008 | 09:32 AM
nomobux's Avatar
ORIGINAL: paedbo
Hope it works out for ya. For about the same $, you could have gotten the 4 Cen 23s complete on the bay.
