Cen MG16RY Battery??
Hi,
I just buy a MG16RY and i know what is the best rechargeable battery for then? I saw in some foruns that they stop easy... And if is possible put some battery pack in the car.
thanks
thanks
.. i saw that a member used a 6v pack. I´ts work fine? or it is better to make the 4,8v pack? and what kind of connector is used? thanks
CA
you can use 2 or 3 prong connetctions--- if you get a 3 prong pack you can just buy a hi-tec or airtronics on off switch (already has 3 prong connection)
6volts is best- receivers can take a max of 6 volts and your servos will perform better
