2nd speed and 3td
how i must loose the screws on the external expanding clutch?(2 nd speed)
the manual of my GST say 5 1/2 turns out but, in my opinion is too much; isn't it?
Its not too much if it is shifting on time.. But if it is shifting early then yes it is too much. Turning it in will cause it to shift later. Just sure you adjust BOTH screw EQUAL amounts presicely EQUAL. Otherwise It wont shift at all because the clutch shoes will bind on the screw threads inside the shoes
