Frustrated, need help Martix TR
I just got my Matrix TR a couple of days ago. While trying to start it I broke the pull string. So I went out and bought a starter box OFNA crome top. When I try to use the starter box it wont turn the engine over the electric motor just comes to a dead stop and does nothing. I'm using the gator clamps to my GMC truck battery to power the ofna box. What am i doing wrong please help....
Frustrated.
Frustrated.
WI
If the engine has not been started or broken in at all, the pinch is going to be really tight. I have a chrome top as well and unless any of my engines are at bottom dead center and warmed up with a heat gun, they are hard to start at first. Hope this helps.
IL
The reason it's not working right is because the engine is raised up about a 1/4 inch to accomidate the pull start backplate. The wheel is then just hitting the chassis before it hits the flywheel. In order for the starter box to work, you need to get a regular backplate. http://www.amainhobbies.com/product_...oducts_id/4331
Thats the one you'll need.
Good luck
If you don't want to lose the pull start, you can grind the flywheel hole wider, but that's tough, and it can weaken the chassis some.
Good luck
The motor has never been started. I was told by the hobby shop that I didn't need to remove any motor shims to lower the motor. The motor's wheel is making good contact with the flywheel. I can tell you I can't turn the flywheel by hand, it is too tight. Does anyone have a picture of this starter box with a Matrix TR ? Thanks in advance.
IL
Yeah, I run the same box, with a Matrix TR RTR. I'm pretty sure the flywheel is not getting in contact with the rubber wheel, and it's just rubbing on the chassis. I'll post some pics..
If you know for a fact that it's making good contact, make sure you rev the motor in the box before you touch it to the flywheel for more power.
Thanks for your help guys, RCnick came out and helped me get my truggy started today. The motor on my starter box is going the correct way, thanks for the tip. The motor I have is the A28, which is on the block. Stopped by Gene's place today and he told me that with this motor i didn't need to lower the motor or change the flywheel. Is this correct. We ran 2 tanks at idle and one at a very low speed. I hope I can get threw a couple of tanks tomorrow. Can the member who posted those pics of the starter box show me how they have their box set up with and without the truggy. I went out and got a new pull cord and now the 1 way bearing is slipping. Great.. I love this truggy but damn.. it's breaking before I get it running.
Yeah i was out there today with his truck and it ran real good. But the one way bearing slipping so soon was kinda weird. Is there anyway to maybe save it cause it is brand new and should not be worn out yet...
NICK - you can try to soak the one way overnight in something like CRC - that can work. You can also replace the bearing itself (and keep the hex it fits into) which is a bit cheaper than buying a replacement CEN one way. TheRealDogman wrote a good instructional piece on replacing the one way bearing -
http://www.cenracing.com/downloads/TRonewaywriteup.doc
This will work fine but I would still recommend just going with the sportwerks backplate - for $12 it stops all that drama.
with the one way slipping for the pull start try and pour a little fuel into the carb i have the same prob and it seems to make the pullstart work right again . same thing when your done with the ater run oil . it would slip ,and i just put after run oil and then pulled it and it worked .
