shift whin 7.7
My genesis is whining when it hits second gear or take off and then stops the whining. Should I be worried? It still seems to work fine but if this is a problem it needs to be fixed before anything else breaks. Thanks
OK, Drove it a little today and stoped to refuel and the gear came off the clutch bell(second gear). That might mean I had the egine sat wrong or it was loose in the first place. I never took these off the bell. What locktit should I use on this gear. Any help or commets would be great. Thanks
Well now I have to get a whole clutch bell. The threads are screwed. My fault really should have looked harder at it. Anyway thanks for all the help guys.
ORIGINAL: The Real Dogman
Dont use locktite if you can help it. But if you must just a very light dab of Blue Locktite. I mean light dab..
BTW. Dogman called it again.. Gears... LOL!!!!
