oil for transmisson?
NY
being that i have my transmission apart now. i was wondering what kinda oil is used on the gears? if there is any that has to go on them. i took it apart cause (you can check my other post under got my ofna primer pump today i posted it there)
thank you
thank you
when i took mine apart i used spray grease on it
something like motorcycle chain lube would be great as it stayes on the gears
not sure as to what other lubricants will do the job
