Air filters
ORIGINAL: bweiler
My LHS can't stock air filters for the Matrix. What are my options here? Is there a cheaper substitute?
I use this on my Matrix works well, fits under the body nicely.
[link=http://www.amainhobbies.com/product_info.php/products_id/9131]http://www.amainhobbies.com/product_info.php/products_id/9131[/link]
VT
Any .21-.28 sized air filter will work fine. 2 stage filters work really good. I use motor saver air filters, the pro-line air filters, and the stock air CEN PRO air filters. All work well. DONT OVER OIL your inner filter. Its a great idea to have a few air filters laying around. One thing I completely didnt respect... ZIP TIE THOSE MOTHERS DOWN TIGHT!!! I lunched an engine because I didnt understand how easily an aggressive roll could rip an air filter assembly off of the carb... All part of learning I guess but zip ties are WAAAAAAAAAAAAAYY cheaper than new engines!
CA
I use o-rings to secure my air filters. I use one o-ring to secure the air filter to the goose neck and another o-ring to secure the goose neck to the carb.
CA
I glue the snorkle to the top plastic filter housing and zip-tie both ends.... when glueing make sure to let it dry properly prior to mounting it on the carb
filter elements are readily availible at our local hobby stores-
