ct5 stearing
NY
hello i am getting ready to run my ct5 since a couple of months ago. i seen that the stearing is very hard to turn. so i charged up my hump pack for an hour. i tried it again with the pack charged up and still it is very hard to turn. i un screwed the servo and the servo turns well with out the linkage attached. so what could be the problem?
SC
does anyone know if this battery fits in the reciever and will it work with the cen matrix tr arean rtr http://www.superiorhobbies.com/istar.asp?a=6&id=LOSB9949!HOR
NY
i dont think its the servo. i took the servo off and tried turing the stearing without the servo connected and it was still hard and tight. so i took of the both front wheels and un screwd them both from the stearing linkage and i found out that only one of my wheels were very hard to turn. so i took that hub off and i think the spacer was to tight. the hub was stripped also so i ordered a set of hubs and the silver piece you screw into the hub over the spacer (number ff044) that should do it.
