CEN Racing This forum is to discuss all CEN Racing products.
ct5 pull start
Old 09-01-2008 | 10:52 AM
Default ct5 pull start
hello i just tried to start my ct5 and i found that the pull was alittle hard to pull but not really hard but a little tension on it. it was never like that. was it because i haven't used it in a while could that be the reason? i did put after run oil in it after useing it but haven't used it in while. i am just making sure there is nothign wrong with it .
Old 09-01-2008 | 11:31 AM
Default RE: ct5 pull start
Did you run it completely dry the last time it was ran? Have you fired it up? Did the tension go away after firing it up?
After it sitting for a while it is a good idea to put some after run oil in the chamber before starting it to lubricate to minimize the chance of dry start damage.
Old 09-01-2008 | 04:39 PM
Hello i haven't even tried to start it. i wanted to see if there was anything wrong with it before i start it up and something breaks. so i will oput some after run oil in it and then it will loosen up. i will start it tomorrow afternoon.
Old 09-08-2008 | 08:01 PM
started my ct5 up today and it ran great i guess it is all ok and miss the speed from it.
