Motor Swaps
I have a few questions that I was hoping the "brain trust" could help me with.
1. I bought a Corsa 5.0 off ebay. For some reason I had it in my head that this the new motor for the GST7.7. I was wrong. So now that I'm stuck with it, I think that I am going to install it in my Matrix Arena TR. Will it just drop in?
2. Assuming that the Corsa 5.0 will work in my Matrix Arena, can I use my SH28 in my CT5? If so, will it just drop in?
Thanks in advance for any advice you may be able to provide.
Keith Cable
Keith Cable
IL
The Corsa 5.0 (.30 cu/in) will fit right in to the TR. Definitely tell us how it works out and how it runs! I heard that there are some CT5s with SH .28s, but I don't think they will fit right in. I don't have a CT5, but I'm pretty sure it uses a small block.
Since you already have the motor, just see if it will fit...that's the fastest and easiest "yes or no" answer. If it doesn't, I think you will have to get some mounting parts for a big block, probably the same from the Arena. Some chassis modification might be needed as well.
Good luck dude!
Good luck dude!
My Feedback: (15)
I have a .28 SH in my CT5 and it fits fine.
http://www.youtube.com/watch?v=aCwplwAkgjY
http://www.youtube.com/watch?v=THhN9oH3xqg
Has anyone out there put a .28 in a CT5? I have seen the videos so I know that it can be done. I am just curious about the exhaust header and whether the motor mounts needed to be modded. Any advice will be much appreciated!
Keith Cable
Keith Cable
