RCU Forums
-   CEN Racing (https://www.rcuniverse.com/forum/cen-racing-310/)
-   -   Matrix pull start (https://www.rcuniverse.com/forum/cen-racing-310/3664531-matrix-pull-start.html)
Dawgnasty4 12-17-2005 06:06 PM
Matrix pull start
I bought my matrix on Thursday. i was trying to break-in today. I pull the pull start cord 5 times and it got stuck fully extended. what can I do?
cenracer1 12-18-2005 09:28 PM
RE: Matrix pull start
sounds like you pulled the cord too far and broke the spring.... you have to take apart the pull start and replace the unit or the spring.. Its probably easier to replace the whole pull starter because it comes complete... You have to be very careful not to extend the cord more than about a foot... short quick pulls work better than long pulls...
Jay-r 12-18-2005 11:27 PM
ORIGINAL: Dawgnasty4
dawg turn the flywheel by hand and it will pull it back in. i havent used the pullstart on my matrix, ive
got several starter boxes. but that happens with a lot of pullstarts, try not to pull it out no more than
you have to
___a reply by Trackman made in the 1/8th scale buggy forum_____________________________________.
Dawgnasty4 12-19-2005 01:36 AM
I tried to turn the flywheel by hand, but to no avail it would not go in. So today I took the pullstarter off and noticed that the string had broken the plastic and pulled threw. I attempted to fix it but the coiled spring came out. I put the coil spring back and retied the pullstarter string. Wouldn't you know it! the cover that holds the coil unit tight broke, so now i'm really up the creek. I either need a new pullstarter unit, rotor starter or a starter box. I'm leaning towards a starter box. Would I need different motor mounts to lower the motor so that the flywheel would work with the starter box? And which starter box should I buy?
P.S. need to get to the track, thanks for your help.
Supertronic Systems-Malta 12-27-2005 09:24 AM
Buy a rotor starter and not a starter box.
Dawgnasty4 12-28-2005 12:06 AM
solved problem guys thanks
