nemesis stalling problem
well i just cant keep my nem running every time i hit hard roll or flip it dies.
even if it hit front bumper and flips back on wheels it dies. any ideas? other problem is idle when it sits it dies if i roll to a stop it dies. i'm new to nitros and would appreciate any advice 3of my buddies have nitros 2.5 tmax 3.3 tmax and3.3 revo and theres just stay running all the time i need to show them this nemesis is no joke but the way it is there still laughing thanks |
RE: nemesis stalling problem
your right up2lt420 the nem is no joke....
its kinda hard to help without seeing or hearing the truck lol but ill try and help as much as i can yea but try putting in a new glow plug. and for the rolling over and diying try a little bit longer fuel line,and MAKE SURE the engine is real tight. and if none of that solves is post back and let me know im sure i can help you ive been playing with nitro engines for 6 years;) |
oh i just thought of it lol most likely its your clutch shoe springs:D
HeadRush ROB 4.6
I assume my theory is similar to yours, please let me know if you agree. The Clutch springs get softer over time due to heat and cause the clutch to engage at a lower RPM and therefore stalling the engine? I've been having the same issue on a Savage where it stalls intermittantly every few minutes and a light went off when I saw your post. Dave |
yea i have a few savages...but any way yea your pretty much right ,when the srpings wear down they dont pull the shoe back and they grab on to the clutch bell and when u try and stop it is trying to go and then when u come to a stop the shoe catchs the cutch bell and stops the flywheel...oh and 1 more thing the shoe srping can also break from stress and cause the same thing[8D]
do you think this maybe the reason for it dieing out when i have a suppen impact?
any time it tumbles or smashes a traxxas it it stalls instantly thank you all for the help i really want to get this worked out. |
yea thats the problem the springs, cause when you hit something and make the tires stop it will die because of the srings
so take your engine out and check before you buy the parts[8D] get all your parts and accesories at www.headrushhobbies.com |
I sounds like a clutch issue...
although you vented bell could be binding...... check your engine mount screws!!! the mesh not only needs to be set correctly but the motor has to be pointing straight the easiest was to get a killer mesh is to disconnect the pipe during engine/mesh set-up |
I just changed the clutch springs and cams on my Savage and all problems solved. Also pops wheelies like never before.
Dave |
| All times are GMT -8. The time now is 09:14 PM. |
