Manifold and Seal problem
Hi, there I have been having a problem with my manifold and seals, when it first happened my silicone seal had a tear around the rim, therefore I changed it but eventhough I changed it to a new seal I purchased from CEN the manifold still slides loosely on the manifold seal. Could this mean my manifold has been widen somehow, if so how can I get it back to near normal or is there some sort of work around I can try before going to the next step of purchasing a new one. |
RE: Manifold and Seal problem
to make it fit better, use 2, then you will have no leaks.
Mine leaked too, So I got a new gasket, then put it in and use a bunch of Hi-temp gasket maker. etween the old gasket and the hi-temp, I have had no issues since.
Try a fresh gasket and a wrap around spring... are you using the two spring set-up to hold the manifold on?
ORIGINAL: notch Try a fresh gasket and a wrap around spring... are you using the two spring set-up to hold the manifold on? I am currently using a wrap arong spring, ditched the two spring set ages ago... |
I am having a problem with this my self. I have the CT5 and two springs. I have tryed high temp rtv twice, and replaced the seal ring just recently. No luck
I don't know which vehicle you are talking about, but my GST had the same problem (Torn gasket). I actually decided to try something differant. I went and got a Savage X Gasket. There's are a lot thicker and take a helluva more abuse. Its works great! You get two of them for like $3 so you will have an extra one. Getting it on was kind of a biatch, but now I don't throw fuel out the back and the gasket is way more thicker and tough then the GST ones.
P.S. A trick I used to get it on was a LITTLE, and I stress a LITTLE WD40. Put some WD40 on the inside of the gasket, not the outside. Slide the gasket half way onto the engine, then slide the pipe manifold over the gasket and it will finish sliding in. Put on the spring and you have a nice tight seal- |
do you guys know what other brand manifold seal would work on my NX-15, I have tried OS .15 seal and it was too thin, did not work.
Any suggestions ?? |
try one the HPI or Hot Bodies silicons. they dont seem TOO BAD, but i ve had those go bad too. the traxxas ones seem to be pretty strong, and ive heard good things on the ofna silicone.
SBG |
ORIGINAL: SBGasser try one the HPI or Hot Bodies silicons. they dont seem TOO BAD, but i ve had those go bad too. the traxxas ones seem to be pretty strong, and ive heard good things on the ofna silicone. SBG |
| All times are GMT -8. The time now is 03:40 AM. |
