gst still having problems
1 Attachment(s)
something else is wrong and i cant figure out what it is. My gst wont move, at first it wouldnt move in forward but would haul ass in reverse and now it wont move in forward and reverse. I checked the shafts and everythings ok, i pulled the tranny out opened it up and none of the gears are stripped. Put the tranny back in and nothing. I played with the forward and rev. adjuster arm on the top of the tranny and got nothing. I can turn the shafts from underneath the truck and the wheels do spin. Cant someone give me some ideas. THANK YOU.
RE: gst still having problems
Well, sounds like you have some kind of drivetrain issue, you might check your differentials and see if they're functioning normally.
If you put the back wheels on the ground and hold up the front wheels, when you spin one of the front wheels does the other wheel spin equally in the opposite direction, same goes for the rear end? Also if you spin both wheels, does the drive shaft going to the center diff spin normally? If all of that seems ok, then I would suspect maybe the center diff or something in the tranny or possibly the motor itself.. When you try and go does it bog down like it's jammed, or just rev and nothing happens? I think I've read somewhere that if you don't stop before you switch from forward/reverse you can snap the shifter shaft in the tranny, that might be it but you said everything inside it looked ok. So yeah check all that good stuff and post back with whatever more info you can, thanks. [8D] |
1 Attachment(s)
Ok found front shaft out so i put it back in and now its back to , in reverse runs good strong wheelies and in forward barely moves and like i said all the gears in the tranny look fine.
Sounds like your oneway bearing on your third gear has manfunctioned. the fact that it will run fine in reverse but not forward, But I would have to take down my tranny to be sure. The manual is not clear to the path of power in reverse. I will pull out my tranny in the next day or two to check it out and see what I find out for you!!! I wish I was more sure without pulling the tranny but, I need to know, now. Besides everything else thats works in reverse would work in reverse, and I have an old oneway I can test my theory. Give me acouple days and I will have your answer for sure. at the very latest by monday..
Well monday came and went and no reply whats up dogman. This gst has sat way more than it ran.
Sorry Devo, Life is whats up. My wife and her car took priority. I will be tearing the tranny down tomorrow to install the new cnc lightweight spur gears. So I will get into it with ya then ok, sorry about missing you this past weekend
wow dogman, thats veyr nice of you maintain HIS truck for HIM. Some people in this hobby just doesnt have the patient and right attitude toward this hobby. You gotta work on your own ****.
Dont compare traxxas to CEN GST. Traxxas is for newbies that doesnt know better... GST rules.... but its not for newbie... |
Devo is your tranny still apart??? if it is then take acouple pictures of it so we can see everything
| All times are GMT -8. The time now is 05:11 PM. |
