RCU Forums
-   CEN Racing (https://www.rcuniverse.com/forum/cen-racing-310/)
-   -   Genesis motor alignment issue! (https://www.rcuniverse.com/forum/cen-racing-310/7769107-genesis-motor-alignment-issue.html)
93firebird 07-24-2008 08:33 PM
I bought my Genesis on Ebay, and who ever set it up has the motor alignment wrong, the second gear pinion is hitting the second gear clutch housing and has worn teeth marks into the edge of the clutch, and the first gear spur is rubbing on the motor clutch, can the motor be moved back or is this a shim issue on the clutch assembly?
The Real Dogman 07-24-2008 08:40 PM
RE: Genesis motor alignment issue!
Sure the motor can be moved back some, but you my need to remove a him from the pinion gears too. The only real way to tell is to see a pic of it, Think you can get a goodclear pic of the motor from the bottom and of the clutch setup? that would help alot!!
CEN Racing 07-25-2008 12:10 PM
You may want to make sure the engine plate is not bent....
BOATRACER1000 05-10-2012 01:59 PM
I just found this thread, I am having a similar issue with my gst 7.7 See my other thread for a pic
