Rally car fix
My dad and I each got one of these
Within 5 minutes he broke one of these Could we use one of these as a cheap fix on both front wheels? This would make the 4wheel drive car into a 2wheel drive. As far as I can understand. Would there be any negative affects or added stress to the clutch, transmission, or engine if we did this. We are both new to rc cars. I've had mine less than a week and he has had his for a day now. Both our cars have been broke on the same curb. I cracked my fuel tank. Used some plastic fusion epoxy type stuff and it seems to be holding up well. Any insight would be very much appreciated. |
RE: Rally car fix
ORIGINAL: kinzuagolfer My dad and I each got one of these Within 5 minutes he broke one of these Could we use one of these as a cheap fix on both front wheels? This would make the 4wheel drive car into a 2wheel drive. As far as I can understand. Would there be any negative affects or added stress to the clutch, transmission, or engine if we did this. We are both new to rc cars. I've had mine less than a week and he has had his for a day now. Both our cars have been broke on the same curb. I cracked my fuel tank. Used some plastic fusion epoxy type stuff and it seems to be holding up well. Any insight would be very much appreciated. |
RE: Rally car fix
You should switch to the factory CEN part, you might be voiding your warranty if you run it in 2WD drive mode. Any R/C car will break parts if it hits something solid like a curb at high speed so I would just take it out somewhere open like a parking lot to get to know your car. You probably want to order a new gas tank from Cen as well because the epoxy might not fully seal the tank...an air leak from the tank could make the engine overheat and hard to tune.
RE: Rally car fix
I've been watching the temperatures closely. 260 F is the highest I've seen and that was with the body on in an outfield (grass) with a lot of WOT (wide open throttle).
As for my dads car. He picked up a similar HPI part as the CEN 2 wheel drive one, so he has been running his car with that. Only down side with that part is that there is a little bit more play in the front wheels. |
RE: Rally car fix
You should switch to the factory CEN part, you might be voiding your warranty if you run it in 2WD drive mode. |
| All times are GMT -8. The time now is 10:13 AM. |
