JR 4500 Nic Met Hyd
JR 4500 Nic Met Hyd
Would a 4500 4cell JR pack be a good choice for the Predator Gasser SE running 9252s i usualy like t fly 25 min flight how many 25 minute flight might i get average Thanks.
Rob
Rob
AB, CANADA
RE: JR 4500 Nic Met Hyd
May I suggest that you charge the battery, have one 25 minute flight, then recharge it on a fevice that can measure the milliamps that it put in. This will tell you how many milliamps it consumes per flight. Then divide that into 4500 mah. That will tell you how many ... and then subtract one flight.
As a courtesy to the others at our field, I only fly in 12 minute segments and it will consume about 380mah per 12 minute flight. So on could extrapolate that your 25 minute flights would consume a bit over 760, say 800.
4500/800=5.62
So you should be safe with 4 x 25 minute flights and 1 of 12 minutes duration.
4500/800=5.62
