OPS .61 Help
Chuck,
I do have a OPS RC 60 (Blackhead). Maybe it is the same carburetor and if so, I can do some measurements and make a drawing of the needle if you want. The mounting is like the Supertigre needle.
I did make a picture of the engine.
Cees
Cees
TX
OK, ha, somewhat wrong about the motor.
It is a Rear Exhaust, red head, rear carb and is a .60 not a .61.
BUT.... it does have a carb like the black head pictured about.
I will post pic tomorrow when I can get my adapter.
Chuck
Chuck
So Gents,
Chuck has a little problem with trouble shooting. Does not have it all very well organized I think.
While we are all waiting for the moment he does find his adaptor back and after that we all can look for a needle valve it was a good case already do some investigation how big the problem really is.
Do we have to look for a OPS 60 (and of course no 61!!!) Red Head rear exhaust (1) and rear carb needle or needle valve? (Chuck?)
Or can we look for a needle of an OPS RC 10 front carb and side exhaust (2)?
Or
Do we have other possibilities in the future, for example the needle valve of an OPS 40 side exhaust (3)?
The answers is, “Yes, yes, yes!â€
If the carb is the same of a (2) engine than also a (3) engine needle probably will fit, see my picture.
So we are all waiting for Chuck, with his OPS powered Mississippi Queen with belt drive!!
His OPS powered Mississippi Queen with belt drive??
Yes because I am also looking for the reason why he did call it a side exhaust engine!
He probably will call a pusher engine a front exhaust.
Chuck, it’s all fun and we are waiting, or do we have to look for an adaptor.
Cees
Or
Cees
Mark, OPS marine engines of the same size can be acquired at auctions for under $100. you might pick up that carb needle you need and even more repair parts. even further, marine versions can be converted to airplane mode with a couple of hours effort.
Chuck,
I did make a picture of the same angle.
There is one more adjustment screw, see the red oval but I think the needles are interchangeable.
When you want a drawing of the needle. let me know and I make one, also with the thread size that is used.
Success Cees
Success Cees
