What pattern plane is this?
Old 05-19-2011 | 11:45 AM
speed-panzer's Avatar
Default What pattern plane is this?
Hi, does anybody know what plane this is?
YS .45 rear exhaust, about 59" wingspan. Is this a Bridi design?
thanks
ID:	1611382   Click image for larger version
Old 05-19-2011 | 12:29 PM
Default RE: What pattern plane is this?
Looks a lot like a Dirty Birdy with a pipe style canopy added. Wing span is wrong for either the standard or the .40 size but could have been a variant.
Does it have a subfin?
Dave
Old 05-19-2011 | 07:37 PM
mikecoul's Avatar
Bridi Great Escape.
http://www.trentonrcflyers.com/patte...t%20Escape.jpg
Old 05-19-2011 | 09:29 PM
Subfin - hard to see from these pics if it has a one.
I will ask fuselage length, maybe this would clarify if it is a .60 size Dirty Birdy with clipped wings. But a .45 engine would be a little small then?
Old 05-20-2011 | 03:35 AM
My Feedback: (9)
not a great escape
Old 05-20-2011 | 06:46 PM
doxilia's Avatar
I'd have to agree with Dave - looks like a Dirty Birdy but the aspect ratio seems a little off (wing to fuse). The DB40 had a flat slab type stab while the original DB60 had a thin airfoiled stab. Both had sheet balsa verticals.
What throws the models proportions off further is the oversize canopy which looks like an Escape/XLT sized/type canopy indeed made for an under the hood pipe setup.
However, both the wing and stab planforms as well as the vertical fin and rudder are 100% Dirty Birdy.
It looks like someone did some "cooking" to it if it was built from a kit.
David.
Old 05-20-2011 | 08:35 PM
Yep, the picture of the bottom shows the wing fairings better. The wing fairings, the square ply wing bolt plate and the wing belly fairing are also 100% Dirty Birdy. No doubt it's a DB of some kind.
You're right, the fuse length would help. And stab construction too, built up or sheet.
Dave
Old 05-21-2011 | 10:37 AM
thank you
