Chip Hyde Jekyll
Old 05-26-2011 | 10:59 AM
Default Chip Hyde Jekyll
Hi all. Im starting to build a Chip Hyde Dr. Jekyll. Im looking for a power plant for this model. Im more into 2 stroke engines instead of 4 strokes. But 2 strokes with rear exhaust ahve been hard to find for me. Suggestions are welcome about brand and size.
Regards,
Christian
ID:	1614893   Click image for larger version
Old 05-26-2011 | 11:29 AM
Default RE: Chip Hyde Jekyll
Christian,
If you can find one, a YS60RE would be my choice. But then again, they are as scarse as hen's teeth these days. A Rossi 61FIRE might be a good choice too.
Good luck with your hunting...........................
David
Old 05-26-2011 | 11:41 AM
dave_anderson's Avatar
My Feedback: (47)
I think Jett Engineering has rear exhaust engines. Ultra top of the line.
Old 05-26-2011 | 11:54 AM
The Jett 90 is 60 size isn't it? Should be enough power I think.
Old 05-26-2011 | 12:24 PM
I checked with Jet and they have a 65 and a 76. Im not sure if a 90 would be to much. All three are available with rear exhaust and pricing is reasonable. Due to the size of the model I thought a 60 size would be a bit to small. YS had also a very powerfull 2 stroke but not easy to find anymore. Thanks for the comments.
Christian
Old 05-26-2011 | 05:18 PM
doxilia's Avatar
Christian,
if its a Dr. Jeckyll and not a Jeckyll, it was sized and designed for 120 4 bangers. I'd plan on a good 90 2 stroke of that's the way you want to go. A Webra 90 or an OS 95 long stroke might do nicely. The Jeckyll, on the other hand, was flown by Chip with a Webra 60 LS in '91. LS 60's are not hard to source including YS 60 AR's (pumped) or even OS Hanno's (quite a bit rarer). You might find an OS 61 RF a little more easily.
I'm glad you find Jett pricing reasonable - they are about the most expensive engines out there other than YS 4 strokes! Nice engines though.
What are the specs of your model (span, length).
David.
Old 05-27-2011 | 09:23 AM
My Feedback: (121)
I'd look for a used OS 140RX (or even a new one). They are dinosaurs from the current pattern perspective (shocking... haha), but a great engine. It will fit nicely in the Dr. Jeckyll especially since it has the exposed pipe tunnel (might hang out a bit). You'll have lots of power with a reliable, easy to maintain 2-stroke. I'd still use a Hyde mount.
My 2 cents
Old 05-27-2011 | 02:03 PM
Common sense would be to determine actual model. I will get the dimensions for you guys to help me out. Then we can decide on engine size.
Be back as soon as possible with dimensions.
Regards,
Christian
Old 05-29-2011 | 04:25 AM
This is Chip's actual #3 back-up for his 1991 World Championship win, originally built by Merle Hyde, just delivered by Dave Guerin. It is painted in exactly as Chip's was and will be powered by a Hanno Special and pipe.
Rusty Dose
Team FUtaba
ID:	1616167   Click image for larger version
ID:	1616168   Click image for larger version
Old 05-29-2011 | 04:40 AM
energyman's Avatar
If it is the 120 size, I would second the recommendation for the OS 140RX. I currently fly a BlackMagic V2, 2 meter plane and it is very reliable withmore than enough power for a 10.5 pound plane and theAMA patterns. Start it, don't even have to run it up, and take off. However, with theES carbon pipe, it takes a very long pipe tunnel. I had to extend the pipe tunnel on the black magic by 8". The proir owner had a YS 160 with pipe installed. Headers are available fromMacs. It runs very well inverted as well. Good luck.
Energyman
Old 05-29-2011 | 09:32 AM
My Feedback: (18)
I would third the recommendation for the OS 1.40RX!! I also have one in a Black Magic V-2 and it's an awesome powerplant...Throttle control is superb and the engine handles very, very well. I'm running the ES Composites CF pipe as well...A winning combination IMHO!!
Chuck
Old 05-29-2011 | 09:41 AM
Glad to see you log in Chuck.
Old 05-29-2011 | 01:45 PM
Christian,
It's hard to tell without the dimensions, but by just looking at the pictures, the stab placement, and chin cowel, I think it looks like a sixty size Jekyll.
If it is a Dr. Jekyll, I can make you a package deal on a couple of OS 140rx's with header, Hatori/OS pipe, new spare EFI bearings, new spare ring, a new Mintor two plug head, a Hyde ARI mount and an new hard to find OS 70B Mixture control carb. One of the engines, pipe, header, and mount has less than twelve runs. Send me a PM if you are interested.
Steve
Old 05-30-2011 | 11:10 AM
Guys have the final word. It is a Jekyll 60 as per the drawing attached. Neverthe less keep the forum open and your suggestions per the engine setup are welcome. I already started to work on the horizontal stab and elevators. Thank you for the help.
Christian
Old 05-30-2011 | 03:35 PM
ORIGINAL: dhal22
I'll second that comment.....
David
