Help with the ID!
Old 06-23-2011 | 02:08 PM
motoman11's Avatar
Default Help with the ID!
This plane was given to me unfinished it was covered in silk i think i painted it and i am now finishing it up know what it is? help 72' wing 56 fuslage
ID:	1626828   Click image for larger version
Old 06-23-2011 | 08:18 PM
stuntflyr's Avatar
Default RE: Help with the ID!
An Acromaster?
Chris...
Old 06-30-2011 | 05:03 PM
motoman11's Avatar
Now i need help with the CG anyone know how to figure it out on a plane like this both the LE and TE have a taper! Thanks
Old 06-30-2011 | 07:35 PM
Measure out half way on each wing. At that point you can determine the average chord by just measuring it. Establish your desired balance point ( perhaps on a piece of tape on each wing). You can try about 30% of that chord back from the leading edge for a fairly safe start on a aerobatic plane. Then draw a line between them to cross the fuelage underneath. That will put you in the ball park.
I hope this helps
Chuck
Old 07-01-2011 | 02:47 PM
motoman11's Avatar
that helps thanks
