SIMLA BUILD THREAD
#801
FL
RE: SIMLA BUILD THREAD
High Guys,
I finally glassed my wings yesterday. I am going to try to finish her up this week. The good news for me is that I am soloing and doing fairly well so far. I have been flying four different aircraft and they are all still in the number of pieces they started with.
Bill
Bill
#802
Hey Bill,
Glad to hear you are still at it. I hope you can get it finished soon so you can enjoy flying it. How about posting the weights before and after glassing/painting so we can compare finishing weights?
Thom
Thom
#803
FL
Thom,
I was out at our flying field today, and the subject of projects came up. More specifically the number of projects that I am working on. It seems that I have seven major projects going right now, including the Simla, a Taurus,a Seagull Extra 260, a Great Planes 50cc Patty Wagstaff Extra 300, a Sig 104" Spacewalker, a Midwest Mach 1 blown up 15% to handle a 15 cc gasser and built from scratch, and finally a 40 cc size Biplane. Lot's of stuff to do, however, my focus is primarily on the Simla and Taurus at this time. Hopefully a week or two is allI'll need to finish them both.
I will try to get those numbers on before and after weights as soon as possible.
#804
FL
Thom
As requested, the unfinished wings weights were 28.4 oz for the right wing and 29.6 for the left wing (that includes all hardware). The glassed wings came to 30.4 oz for the right wing and 31.0 oz. for the left wing. More to come when I have finished the wings later this week
Bill
Bill
#805
CT
I have a question,Do all SIMLA'S have to be painted/covered in the original scheme? I was wondering if it would be Sacrilegious to create a different covering scheme.
stefanP
stefanP
#806
FL
stephanP,
Perhaps it would be better if Duane commented here, but apparently at least one of the proto types had a different finishing scheme. I personally chose to follow the original scheme in the spirit of trying to recreate a Simla similar to Ed's. My second Simla will have a paint scheme considerably different from the original.
As far as chosing paint over one of the popular plastic coverings, I just prefer the results I get from painting. It is a lot more work and I have alot more time invested, but it just produces a smoother, sleeker appearance on the finished product. Painted surfaces also do not wringle when exposed to the sun. But of course at altitude and speed no one can see the difference between a painted plane and one that has been covered with plastic. The down side of painting an airframe is of course the added weight; but with a little effort and practice the weight difference can be overcome to some extent.
Bill
Bill
#807
ORIGINAL: billberry189
stephanP,
Bill
stephanP,
Bill
You have to keep in mind what we were trying to do in the Simla project, and that was to create the original Ed Kazmirski Simla as close as possible to the "look" of Ed's original model. To us that meant the exterior appearance, and of course the paint scheme. A lot of improvements have come "down the pike" since 1965. The interior workings reflect a modern CF wing tube, and a different method of wing attachment than Ed used, (which would no doubt be thought of as crude and very heavy today). Our intent from the start was never to absolutely duplicate Ed's model as he originally built it...just the exterior model and its shape and dimensions.
Our original hope was to have all three prototypes finished at the same time, (with the same Kazmirski paint scheme), and included in a photo for the magazine article, however by the time Kevin's Simla was ready for finishing, the original prototype used in the article had flown, and the article was already published. For that reason Kevin "went wild" with his scheme (which I think is Monokote, and is lighter). I decided to use fabric and paint, (which I almost never do) in this case just because of the model, the article, and the historic significance of the aircraft itself. Notice in the pictures below..... Ed with his plane, the original dimension photo, the magazine prototype, and finally Kevin's own color scheme for his model which flew a few months later.
A second Simla when it comes may have a "Kazmirski-like" scheme in the same colors, but the plane may be modified quite a bit. Kevin and I have talked a lot about what a "modern day" Simla would have looked like if Ed were designing it now...something for 2-meter AMA competition. We were thinking of the mods we'd make, (as if we were modern-day "Ed"s), to build a 2-meter plane. That would be a fun project for us with a completely different goal in mind, which will give a totally different outcome.
#808
Has anyone modeled the Simla for the RealFlight R/C simulator yet? It would be fun to fly it on the computer as well, especially as it is over 100 out today. There we could see how it flies with .60, .75 .90 and 1.20 engines
#809
thom, you may have that fun but not for free. Maybe better Duane should comment on it, so only this: It was part of the Simla resurrection project that I rendered several variants (wing, weight, drive) in a simulator to see how they fly (three years ago). Duane has them all. It's just not RF but Reflex XTR. There might be a FSone rendering as well and if so, Andy Kunz should be able to comment on that.
#810
Hi,
Here is a nice Simla plane shown at F3A Retro Day in Schwitzerland July 7, 2012 - see image below. Link where it is shown:
http://www.leodolter.ch/index.php?op...d=37&Itemid=42
Built from theSimla kit I assume?
/Bo
/Bo
#811
ORIGINAL: bem
Hi,
Built from the Simla kit I assume?
/Bo
Hi,
/Bo
I know just enough German to not be able to quite understand the captions.
Duane
#814
CT
Well after much thought I will use the stock colors on mine too.BUT I will fly the plane on a ASTRO FAI 60 Cobalt motor direct drive.Yes mine will be electric powerd.Only moderen aspect is that the plane will use Lipo batteries.
stefanP
stefanP
#815
ORIGINAL: stefanP
stefanP
stefanP
Electric is the up-and-coming method of propulsion...good luck. That is going to be one LARGE plane being powered electronically.
Duane
#816
ORIGINAL: kingaltair
Duane
Duane
#817
ORIGINAL: UStik
Yes, and it is an especially well suited one (remember it's an aerobatic motorglider).
Simla DOES like to glide.
Duane
#820
Jeff recently received this message...it is the kind of message kit developers/manufacturers LOVE to get: Does this mean he has Simla #5?
Looking forward to pictures.
Any word on the other Simla(s)??
Duane
Howdy Jeff:
Well, we finally got the maiden flight done on my SIMLA. What a beauty it was in flight. My club instructor flew it for me and it was truly awesome. The SIMLA did everything my pilot asked it to do and it did it all so superbly. Several folks took pictures and if you are interested I will send you some in the mail. Let me know. Ed Kazmirski would have been proud. What an airplane. Thanks for producing the kit. I have many RC airplanes but the SIMLA will be one of my favorites.
Jim Young
Duane
Howdy Jeff:
Jim Young
#821
Duane,
I am still flying mine. What a plane! At our club's recent big bird fly-in the Simla was a big hit. Many questions about it. Several people wanted to know where to get one. I referred them to Jeff's web site ClassicRCHobby. I hope he will still produce kits.
Thom
Thom
#822
ORIGINAL: thom25
Duane,
Thom
Duane,
Thom
I'm sure Jeff will find a way to keep the Simla available down the road.
Duane
#823
FL
Hey Guys,
Well, I am still alive and plugging away at it. Today was a "red letter day", as I finally painted the wings. Tomorrow one of the local clubsis having a picnic so I will be there taking some pictures of my Simla. Unfortunately I won't be flying her just yet since I ran out of time today and did not get the ailerons or servo covers painted. But since they both are red only, I should be able to finish them next week. Since I will be out of town next weekend it will be the weekend of Oct. 13, before I get to maiden her.(Good thing I'm not superstitious) lol.
Bill
PS- She came in heavier than I expected at 13 lbs even. I am going to invest some time in losing some of that weight.
Bill
#824
Bill,
Even if your plane was 15#s it will fly very nicely! Can't wait to hear about your first flight and see some pictures. If you get some spare time could you figure how much the fiberglassing and painting weighs in total on your Simla?
Thom
Thom
#825
CO
I was just wondering what kinds of electric motors folks have been putting in their Simlas. I'm thinking along the lines of a Scorpion S4020-12 or S4025-10 - will it fit OK?
