Building a Tiporare .40
Yes, I´m using the wood size you recommended me,but not in the lighter side of the scale in ome cases. I´ll sand the wing and stabilizer sheet maybe to 1,2 mm. and 1 mm. respectively.<o></o>
Thank you David! Very interesting notes.<o></o>
Do you think that those two spars that travel to de main landing gear support are necessary in this model?<o></o>
Thank you David! Very interesting notes. Do you think that those two spars that travel to the main landing gear support are necessary in this model?
I was going to ask you whether you planned to put the stub spars in. It's not a bad idea and shouldn't add much weight. They provide some structure to the wing in the retract area.
An alternative would be to add some CF tape on either side of the retract plate to the root - basically the same as balsa stub spars. I would also add some CF tape to the top of the wing. A 10 mm width is more than enough running 3/4 of the wing panel span. Once sheeted and joined, that wing top tape will prevent the wing from bending at all upon landing.
I guess these are "peace of mind" mods. Many a wing has been built simply with the plates like you have them installed and straight forward sheeting. If you plan to cover the wing, I'd add the spars or CF. I you plan to glass and paint it, then I'd omit them except possibly for the wing top CF strip. Any additional weight comes from the epoxy. The CF weight is negligible.
I applied CF tape to a small 40" wing which in retrospect was way overkill; I could have used much less:
http://www.rcuniverse.com/forum/fb.asp?m=8310704
I built my Tipo 60 wing with CF too but being more diligent with its use. One thing's for sure - they turn out to be rock solid!
I would also glass up the wing center section once joined in three sections. 4 oz 2" strip, followed by 2 oz 4" strip, followed by 3/4 oz strip out to the edge of the inner wheel wells. The wells are the "weakest" part of the wing due to the thickness so this is where the stub spars, CF and/or glass come into play. Glass for the top of the wing can go out only to the edge of the fuse. Use dilute laminating epoxy if you can using as little as practically needed.
David.
A suggestion. Much of the weight in a balsa covered foam wing comes from the epoxy. You don't need much epoxy to get the job done.
When I used to sheet foam wings we would apply the epoxy to the foam and then spread it out and scrape much of it off to leave just enough to hold the balsa.
You might try some tests first to see how light you can go with the epoxy. Use a syringe to apply a small bead of the epoxy where needed.
Good luck. You work looks fantastic.
I have a Tiporare 60 that I will be flying this next summer in the Chicago area.
birdman2
what motor is everyone going to use? and I assume eurka rc would cut the foam wing?
Chino,
I find that applying epoxy to the sheeting is much easier. One can control the glue and it is also easier to apply as the sheets are separate and one can stack the sandwich when the sheets are prepared.
Something to consider...
David.
Strenght is equal and maybe better, just spray a generous ammount of SUPER 77 on both surfaces, allow to dry and join both pieces, put some weight over wing and let dry.
Thank you for the nice comments and suggestions.<o></o>
I´ve used Great Planes 30 minutes epoxy and the stab looks very good and light. <o></o>
David, I´ll put the stub spars but I don´t think to use CF.<o></o>
Thank youCloudancer03, I hope to see your build thread.<o></o>
I need to buy somemicroballons first to do that, but I think that I´ll use them. Here inArgentina is difficult to get some materials.<o></o>
I read about the lighting holes technique in a F3A building book (it is in this forum in PDF), and is the first timeI use it. I am going to see how it works.<o></o>
Regards,<o></o>
Chino<o></o>
Greetz Erik
good stuff! I know we talked about it before but if I may make a suggestion, I'd recommend not installing the stab in the fuse until the latter is completely finished, carved and sanded down to 220 grit. I find it is much easier to do the job and verify symmetry without the stab interfering. The stab is the last thing I install permanently once the wing and the fuse are finished, have been squared up and mounted. As I'm sure you already experienced with the Curare, getting an anhedral stab installed and verified in the various axes and dimensions is quite tricky.
She's coming along very nicely!
David.
