Anybody interested in a NEW YS shortstroke? New, as in produced this year...
#126
My Feedback: (39)
CA
RE: Anybody interested in a NEW YS shortstroke? New, as in produced this year...
WITH ALL THINGS BEING SYMMETRICAL, TO AVOID YOUR BASIC TRIMMIMNG ISSUES WITH THAT MASS HANGING ON THE SIDE, WOULDN'T IT BE PRUDENT TO DO A LATERAL BALANCE (EMPLY) PRIOR TO FLYING (RETRACTS UP, PIPE MOUNTED).I'VE DONE THIS MANY TIMES AND IF ONE SIDE WAS LOW, I'D ADD WEIGHT UNTIL IT BALANCES OUT BUY MEASURING WING TIP TO SURFACE. THE WEIGHT THAT WOULD BE ADDED WOULD BE BURIED IN THE WING TIPS AND COVERED. I'VE ALWAYS MAINTAIN A 10 DEGREE DOWN THRUST (PITCH) AND MY LATERAL BALANCE WAS PRETTY MUCH EVEN - JUST THE WAY I BUILD.
#127
My Feedback: (92)
What I was referring to was the location of the vertical CG. Having the pipe above the wing instead of below it raises the vertical CG and will cause the model to pull to the canopy in a vertical climb. Also, it causes a reduction in the side area of the model and will change the rudder response, potentially causing a roll with rudder. Not saying it couldn't be worked out with trimming, but I've never felt Phoenix's with the pipe down the side flew as well. To each his own!
#130
Okay Guys,the latest info!
#131
Okay Guys, just an update . . . . . Time to put my YS Hat on!!!
