Go Back  RCU Forums > RC Airplanes > Pattern Universe - RC Pattern Flying > Classic RC Pattern Flying
 Pilot Cavalier ARF from 1971... remember? >
Old 11-10-2015 | 12:32 AM
Ah, okay, I understand.
The fact that it expands means that it is not suitable for the ABS parts as they need a full surface contact.
I will now make some ABS test pieces and see what foam safe CA does, and I will also buy some acetone to see if that also works.
Thank for the reply!
Regards, Gert
Old 11-10-2015 | 10:17 AM
My Feedback: (121)
Hi Gert,
I don't know if I can buy an MEK type adhesive here, but plastic model cement of some type should be available in a model shop near you (if they sell plastic models). We have something called Duco cement and Wal-Mart sells a generic equivalent. I believe Graupner sold the appropriate adhesive. Straight acetone will soften/dissolve the plastic, but it will never harden - just stay a gooey mess.
Good Luck,
Will
Old 11-11-2015 | 02:04 AM
Hi Will,
Thanks for your advice!
I will really first have to do some testing with different types of glue.
Coming weekend when I have time I will see if my local paint shop still has some MEK (I believe it is not allowed to be used anymore here in the Netherlands)
I will keep you informed what the outcome will be.
Regards,
Gert
Old 11-15-2015 | 08:32 AM
bem
Hi,
I would try this to get the ABS parts glued together:
http://www.humbrol.com/uk-en/liquid-...ml-bottle.html
(Watch the video)
https://www.deluxematerials.co.uk/gb...243900210.html
(Watch the video
/Bo
Old 08-19-2020 | 11:46 PM
Someone is making an ARF of this one available in Japan
Old 11-28-2020 | 11:45 PM
  #31
Hello!!
I hope this finds you well after all these years!!
I just found one of these NIB!!
I was wondering which month of MAN this was in?
You say August 1971and the picture you posted says June 1971.
If you can could you please confirm as I would like to get that info PLEASE?
Jeff Sawyer
Lancaster, Ohio USA
