EU-1a Elecrtic Conversion
Old 06-18-2015 | 03:09 AM
  #76
Thanks Dale. Don gave me 1-1/4" - 1-3/4" from Robert F., but I don't know what he chord measurements are to compare. But alas, my kit ships Friday!!
Old 06-18-2015 | 01:42 PM
  #77
KLXMASTER14's Avatar
Originally Posted by SanJoseDale
I moved the CG why back, to 36% MAC, it just barely sits on the main gear. That seemed to cure about 90% of the canopy pull. I tried thrust and incidence changes, with little effect. It seems to fly fine at this point. The dihedral was NOT set in the cores from Don. His suggestion was to build with the top of that panels on a flat surface. The new wings are being build by Dave Snow (not foam), as a one piece wing. The dihedral angle is 1.333 inches, measured from the root center line to the tip center line, on each panel, which is more than where I started.
That will result in a significant increase in dihedral. Mine has 1-1/4" each tip, but measured from the table to the BOTTOM of the wing tip. My aircraft has a good bit of adverse roll with rudder application. Might be time to get out the saw.........
Robert
Old 06-18-2015 | 01:44 PM
  #78
Robert
Yup, considerably more. i cut into the wing twice to get it right.
Old 06-19-2015 | 12:53 PM
  #79
stuntflyr's Avatar
On the Circus Circus model it was flat, on the Blue Angel EU-1A I'm flying now it's different.
If you stretch a string across the top from wingtip to wingtip it's 1 inch from the string to the top of the wing in the center.
Chris...
Old 06-19-2015 | 04:57 PM
  #80
My Feedback: (121)
What do the original, all wood, plans call for?
Old 06-20-2015 | 06:21 AM
  #81
i don't think there was an all wood EU 1a, it was always foam and glass. There are plans for the non a version, but that was different. On the foam cores, the instruction had you join the panels in their lower blocks to set the dihedral, no angle is mentioned.
Old 06-20-2015 | 06:47 AM
  #82
My Feedback: (90)
may be talking about the wood and foam EU1
Old 06-20-2015 | 01:27 PM
  #83
The Fling Models article about the original EU1 (Interestingly, "Ellen Ullery" -1, for his wife) was an all wood one. Not sure how many were made but plans are out there. It was quite a bit different than the EU1A, in composite. The wood one was bigger.
Would like some comments on how the different dihedrals fly, and what's recommended.
Old 03-31-2016 | 05:21 AM
  #84
My Feedback: (90)
Hi SanJoseDale,
Are you still flying the EU1A? Can you tell us the finally dihedral you went with and how the aircraft handles with it?
Old 04-01-2016 | 06:04 AM
  #85
I have not yet flown the new one, but did make the dihedral change I mentioned above. I was able to eliminate much of the roll coupling.
Old 04-04-2016 | 05:28 AM
  #86
My Feedback: (90)
Hi SanJoseDale,
I see where you mention that you cut the wing twice and made changes, but I do not see where the final dimension for the dihedral. Did I miss it?
Old 04-04-2016 | 06:23 AM
  #87
Post 75,
Old 04-04-2016 | 06:36 AM
  #88
My Feedback: (90)
LOL. thank you for pointing that out. I didn't know if that was before or after the "cutting the wing twice".
Old 04-04-2016 | 06:46 AM
  #89
Yeah, that was where I ended up after cutting twice, so new wing was built to that. I have not yet decided if I should move the stab location as some have suggested.
Old 04-04-2016 | 06:48 AM
  #90
My Feedback: (90)
Are you talking about lowering it 1/2 inch and putting a 1/2 anhedral in it?
Old 04-04-2016 | 06:55 AM
  #91
Can't add anhedral now, it's already built with carbon tubes, but yes, considering lowering the location a bit.
