Howard Engineering - Kwik Fli III – Build
#76
My Feedback: (12)
FL
RE: Howard Engineering - Kwik Fli III – Build
When you did the epoxy finish on the hor. and vert stab., did you thin the 30 min. epoxy or prep the balsa any way before starting it?
thanks, Tom
thanks, Tom
#77
My Feedback: (17)
ORIGINAL: tph1
thanks, Tom
thanks, Tom
I just did the vertical stab with the epoxy and about ½” out from the fillets on the root area of the horizontal stab. The horizontal stab will be covered with Monokote. The vertical stab balsa was sanded smooth like you would to prepare for any finish. The 30 minute epoxy was applied with a squeegee and the epoxy was not thinned. The balsa surface absorbs a small amount of the epoxy and on the first coat the idea is to squeegee most of the epoxy off other that what has been absorbed into the surface. After the first coat sets the surface of the balsa is very hardened with the epoxy. Before you start sanding the epoxy it must be fully cured and hard to make it sandable. You might try the process on a scrap piece of balsa before you start on your aircraft but it isn’t very complicated.
#78
My Feedback: (12)
FL
OK thanks. I think I will experiment with it on a scrap first but I think I'm going to paint the hor. stab on my Temptation. I only want to cut the trim scheme once and painting the stab would help that.
Tom
Tom
#79
My Feedback: (17)
ORIGINAL: tph1
Tom
Tom
#80
My Feedback: (12)
FL
I just tried it on a scrap piece. I put it on with a plastic cake icing spreader and it looks like it did well. I will know later when it dries.
thanks again
thanks again
#81
My Feedback: (17)
ORIGINAL: tph1
thanks again
thanks again
Sounds good! The key thing is to let the epoxy setup real well (usually over night) so it is easer to sand and use fresh sand paper to sand each coat.
#82
My Feedback: (12)
FL
Did you do any filling before the epoxy? I'm going to do the bottom this afternoon and the top first coat tomorrow if it looks good.
#83
My Feedback: (17)
ORIGINAL: tph1
#88
My Feedback: (17)
After the vertical stabilizer epoxy finish was completed I covered the horizontal stabilizer, which will be covered with MonoKote, with plastic wrap and taped it off. I then washed the outside of the fiberglass fuselage with warm water and dish detergent (making sure no water got inside the fuselage) to remove any finger print oils or other contaminates from the surface. I dried the fuselage well and then sprayed on a light coat of the LusterKote primer and then a couple of heaver coats. I consider the first primer coat expendable because it really helps to highlight any areas that need more sanding and finish work. I was extremely happy to see that the fiberglass repair work I did looks excellent, very smooth and straight
One of the advantages of the fiberglass fuselages like the Howard Engineering fuselages that are not jell coated is that any pin holes in the surface are readily visible on the first primmer coat. Often with jell coating they hidden under the thin layer of jell waiting to break though the jell to expose a big nasty pin hole. Also the non jell coated fuselages let you see through the glass when you are installing firewalls, etc. There were very few pin holes and I filled them with automotive glaze. I use an artist spatula to apply the gaze. The artist spatula is used for mixing oil paint and doing certain types of oil painting. It has a very thin faxable blade and is a perfect tool for the glaze. The images below show the first primer coat and one of the pin holes that I circled with a red line.
To be continued..
To be continued..
#90
My Feedback: (17)
Using the spatula a very small amount of glaze is forced into the pin hole. After the glaze is dried the area over the pin hole is wet sanded with 800 wet paper and a sanding block. This should remove all of extra glaze and make the area smooth. The before and after images are below.
To be continued..
To be continued..
#91
My Feedback: (17)
After all the pin holes are located and filled with glaze I wet sanded the complete fuselage removing much of the primmer so it will fill any low spots and not add weight. The fiberglass has had thirty years to cure and shrink on this fuselage so a little more weave shows but not much.
To be continued..
To be continued..
#95
My Feedback: (72)
Thanks Warren! This is the time consuming part but I just take my time and enjoy the experience.
#96
My Feedback: (17)
I found some heaver coat hanger wire that is close to 1/10” so I replaced the thinner white wire with the heaver gold colored wire. I expect that the 1/10” is the type of wire I used on the original not the 2005 vintage thin wire.
To be continued..
To be continued..
#97
My Feedback: (12)
FL
I just got home and took some 220 grit sandpaper and sanded the coat I put on yesterday, basically knocked the shine off of it, I'm going to go for coat #2 now. I think it is working according to the 8178 plan, looks good in other words
thanks
thanks
#98
Will you upload some photos when it is complete. Great posting, I have an old fibreglass fuselage which has cirelated around the local rc club for 20+ years. It needs a cowl and a similar treatment as your kwik fli. Your posting is a great help. Thanks.
#99
My Feedback: (17)
ORIGINAL: jpurcha
#100
Actually, if you liked Hobbypoxy Formula II, it's still made, more or less:
http://www.pettitpaint.com/products2...=3&SubCatid=10
So's the Formula IV 5-minute:
And Formula III Thixotropic:
They got out of the hobby business and now sell only to the marine business, but you can still get the products.
