Kraft Retracts
Old 08-13-2006 | 06:18 PM
Default Kraft Retracts
I bought a used Pica Duelest, that has a set of Kraft electric retracts in it. The retracts and the control unit are there, but the battery is missing. It has a four pin connector with two black and two red wires. I assume the reds are positive and the blacks are negative. Anybody have any input that might be of help ? I can fly the bird with the gear down, but I would like to use the gear.
Old 08-13-2006 | 08:06 PM
Mike Denest's Avatar
Default RE: Kraft Retracts
Change the connectors to match the radio you are using, just make sure that you get the wires correct.
Old 08-14-2006 | 05:16 AM
There is already an adapter to plug into my radio.
I figured it out last night, the 4 pin plugs in the leads from the mains.
