Marksman mid-wing design
Old 01-06-2007 | 10:26 PM
Default Marksman mid-wing design
In the later sixties, I flew with a fellow who had a fiberglass fuselaged mid-wing pattern design called the Marksman. The wing was tapered, and built-up, and the rudder hinged with a swept-forward hinge line. The plans (which I have scanned copies of) are signed P A Ennis. I seem to remember that the designer's first name was Paul, but that may be incorrect.
Does anyone else remember this airplane, or anything about it or the designer?
Old 01-06-2007 | 10:42 PM
My Feedback: (14)
Default RE: Marksman mid-wing design
ORIGINAL: cwahl
The name does sound familiar, but I can't recall anything more at this time. Given a few days, more details may emerge from the depths of memory.
The original swept rearward rudder hinge line (ala Taurus) was thought to add a bit of up elevator effect when the rudder was applied. This allegedly helped in mild coordinated turns by reducing the number of elevator blips needed in a turn when using the old reed systems with full on or off rudder movements. I fail to see any benefit to sweeping the rudder hinge-line forward.
Ed Cregger
