correct prop size??
My Feedback: (17)
TX
I would suggest starting with an 11 X 9 on up to a 11 X 10 or a 12 X 8 or 9 or 10. You want to keep the rpm's in the mid to high 9's. The prop that will provide the best vertical is what you will want, and you can use throttle management in your straight line and down line flying. You didn't mention if this was a long stroke engine. If it is a long stroke, you can probably increase the length of the suggested props by one inch. Hope this helps.
GPB
GPB
My Feedback: (20)
TN
Or if it has a red head and is a Hanno Special, then you want 12 x12, 12.5 x 11.5. I say this because there was recently a Boxer for sale with a Hanno, and I wondered if that is your plane.
I just finished building a Boxer .60 this past fall. Mine has yet to be flown. It has an OS .60fx for power ,and Dave Brown retracts. As far as I know there was never a kit. Plans are still available.
Jim
Jim
