Utter Chaos Plus!!
Old 07-05-2007 | 10:41 AM
Skip's Avatar
My Feedback: (76)
Default Utter Chaos Plus!!
I recently bought an Utter Chaos kit on RCU ands thought I could modify it to use an OS .91 Four stroke for SPA contests. . I spliced the fuse in several locations and widened the fuse 1/2 inch to accomodate the engine. I had to lengthen the fuse to compensate for the extra engine weight. You will notice I also placed the elevator and rudder servos in the rear fuse to counter this weight. I has worked out well. Todays' test flights went well and I like the way the plane flies. I need to move the battery aft slightly to compensate for slight nose heaviness that is still there. Throughout the construction process I continually did c/g checks to make sure I was going to come out OK. Here are the pix from todays test flights ( 7/05/07 )
Old 07-05-2007 | 02:20 PM
Default RE: Utter Chaos Plus!!
Skip, Nice plane. How much did you stretch the fuse ? I have a tower kit i'd like to use my 91fs in. Did you use two elev. servos or bellcrank system?
Old 07-05-2007 | 04:26 PM
Skip's Avatar
My Feedback: (76)
I stretched the fuse 1 inch forward of the wing saddle and three inches aft. I only use one elevator servo and it works just fine.
Old 07-05-2007 | 04:31 PM
Nathan King's Avatar
Looks beautiful, great work! [sm=thumbs_up.gif]
Old 07-05-2007 | 04:51 PM
Deadstik's Avatar
My Feedback: (8)
Looks Like A DUCK!!!.....ROFL....
Dan
Old 07-05-2007 | 04:55 PM
Must be a duck.
Old 07-05-2007 | 05:08 PM
Looks good. I still don't like the canopy on the Utter/Killer, but she is still a bute.
Old 07-05-2007 | 08:07 PM
Skip's Avatar
My Feedback: (76)
I actually had intentions of using a larger canopy but decided not to at the last minute. I was afraid it would blank out the small rudder. Skip
Old 07-30-2007 | 07:53 PM
Great looking Utter Kaos! I got one myself I fly in SPA also. I use an Old OS .61FSR and hauls it around pretty good but I would like to try a .91four stroke on the next one. Just curious how your's performs with the .91 FS, and what did it weigh in at?
Jim H
Old 07-30-2007 | 08:35 PM
Skip's Avatar
My Feedback: (76)
Sorry about the delay I just moved to a new house and was without a computer for a while. The plane flies great with an OS .91 four stroke. I've never weighed it but my guess is about 7 1/2 pounds.
Old 08-01-2007 | 01:46 AM
My Feedback: (14)
A beautiful effort. But now the wing looks too small...<G>
Ed Cregger
Old 08-03-2007 | 01:11 PM
blw's Avatar
blw
Hi Skip,
Good to see your Utter Kaos. I have a kit reserved and it will be on the way from a friend soon. I'm thinking either a C. Lee K&B .61 or a Saito .91 for mine. I have the K&B now.
Hope things are working out for you since we last talked here in Auburn. I'll PM you.
