Fresh Aire
Fresh Aire
It's coming... An occasional dusting of frost, the yard speckled with leaves, and a cool breeze...
FALL!! Which means building time!
While looking for a project this winter I came across a Fresh Aire kit, immediately gobbling it up. After looking for one year I finally found a kit of this beautiful model. In case you haven't guessed yet, I will be building it this winter and posting my progress on this thread.
For those that don't know I like to research my subject and thoroughly get to know the model, it's capabilities, intended flight envelope, specifications, and it's designer. The Fresh Aire was designed in 1987 by Doug Ferguson who is an avid pattern pilot and works in the full-scale aviation industry. The prototype first flew in 1990, and after slight modification (kicking the wing tube against a fence) flew beautifully. This successful model was later kitted and sold by "RC City". The airplane was originally designed for a YS 1.20, but I plan to install a YS 1.10 since it's lighter and has comparable power to the older engine.
Day 1: - Wednesday, September 5th
My kit is an original before it was mass-produced, and the quality it top notch!
The wings have been honeycombed and servo/retract slots have been cut out. I plan to use Spring Air retracts. The leftover "angel hair" foam has since been removed.The left and right wing cores weigh 39 and 41 grams respectively. The left horizontal stabilizer core weighs 11 grams, and the right horizontal stabilizer core weighs 8 grams. The fuselage weighs 552 grams, and the canopy weighs 49 grams. The engine pan weighs in at 96 grams.
Is it just me, or does this airplane have beautiful lines?
Due to time/money constraints (College) coupled with my perfectionist nature this build will take quite a while. Be patient, I am working on it.
To Ed Cregger and other non-fans of honeycombed wings:
True, honeycombing does not remove large amounts of weight; however,
lightening everything you can slightly really adds up. This, coupled with the fact that
less outboard weight will improve the response and "crispness" about the
longitudinal axis. This makes for cleaner rolls and tighter snaps.[8D]
RE: Fresh Aire
To each his own. I really don't want this to become a honeycombing debate, so my final word on this will be that it's not just about weight. Weight distribution has much to do with how the model will fly. Even a little weight that far from the control axes and center of lift can make a pronounced difference in handling. Think of a "teeter-totter". A 50lb kid sitting 10 feet from the center will equal a 100lb kid sitting 5 feet from center. Each gives 6,000 inch pounds of torque, but less weight was used on one side. When a model only weighs nine pounds, a couple of ounces are a large percentage of total weight. My airplanes are not "worse" for having it and yours are not "worse" for not having it. Do whatever you like.
theSteam (03-28-2021)
My Feedback: (121)
RE: Fresh Aire
The Fresh-Aire has very elegant lines, reminiscent of the Silent ST that NAruke designed (first 4-stroke pattern ship). I'm sure it will fly well with a YS 1.10.
As for honeycomb wings... been there, done that. A PITA for marginal flight improvement. I built 4 Mistresses - 2 without and 2 with HC wings back in the early 90's. I bet digital servos would have done more to improve flight performance than HC. The current designs all have more highly tapered wings and I'm not sure there's enough area to justify the effort. Of course most of the current pattern designs are ARFs so who knows what lurks beneath, though I think most of the Asian planes are all balsa.
Looking forward to seeing pictures of the completed Fresh-Aire!
FL
RE: Fresh Aire
One should consider that, along with the reduction in weight from the foam that isn't there as a result of honeycombing, there is also the reduction in weight from the glue that isn't there to fasten the sheeting to the foam that isn't there--assuming you apply your glue to the cores instead of the sheeting during the process, of course.
Rick
Rick
RE: Fresh Aire
Hey, I'm still here. I apologize for falling off a cliff but couldn't get much of anything done during building season since I was forced to relocate my wood shop from the basement to the garage. You-know-who was tired of dust being tracked upstairs despite my best containment efforts. []
I am now left with building during the flying season. This is fine since we've had some real crappy weather lately (snow, rain, and driving winds). The flying weather around here during summer is really made up of non-flying days punctuated with the occasional good day, so there shouldn't be much trouble finishing this. Oh, how I love living in the plains!
Anyway, I am currently cutting all wood pieces to make a 'kit' before assembly. I am, more specifically, working on the fuselage formers. Instead of taking the plans to a copying facility I use the old waxed paper copy technique. The paper is taped to the plans then carefully cut with a razor blade. This requires a light touch but isn't difficult since the waxed paper cuts so much easier than the underlying plan paper. After the copy is cut (on the outside edge of the line of course) I use it to trace the pattern onto the final wood. The wood is cut with a bandsaw and sanded carefully before being stamped with a number in red ink corresponding to the plans.
RE: Fresh Aire
ORIGINAL: dhal22
i finally started cutting parts for my Blue Angel project and am using wax paper in a similar way. i'm watching this one also.
david
david
I plan to get wood tomorrow to start sheeting the wings and stabs (once my retract mount is in). That will be fun!
My Feedback: (121)
RE: Fresh Aire
Glad you finally got back to building!! 'You-know-who'?? I presume you're married... You gotta take a stand, man! I've been 'married' to this hobby since the '60s and my wife since the '80s... don't make me choose!!
I haven't used the waxed paper method since the '60s! Now, you can also buy a translucent plastic material called 'See-Temp'. About 1/32" thick, it makes great templates that are quite durable. Of course, you can't beat the price of waxed paper!
Anybody remember 'oiling' the plans to build wings/stabs? You literally applied oil (preferable vegetable oil) to the plans so you could see the outline from the back (the reverse). I think I built a few free-flight models that way. There are MUCH better methods!
Keep posting your progress, Nathan. Very enjoyable to watch!
Regards,
Will
Regards,
Will
RE: Fresh Aire
I was planning to post progress pics today, but instead you get a small rant. I apologize in advance...
Where do you guys get your balsa?? I'm done foraging all over town just for enough good balsa (and still overpriced) to complete a project.
QUOTE: Crabby Rant Guy
Now I remember why I hate building. Actually, I love building but hate the hoops you are forced to jump through just to do anything. Case in point: purchasing wood. I went to my hobby shop (which will remain nameless) for some balsa. I brought my gram scale because I like to build airplanes that fly well. Anyway, I pulled all the wood they had and set up my scale. After looking through I found that they didn't have ANY c-grain. Fine, pull out the a-grain (which was all they had) and start weighing. Now, a good sheet should have weighed somewhere between 9 and 19 ounces to be acceptable. Let's see here, 28g, 32g, 48g, 52g, 35g, etc.. Guess how many pieces of wood I walked out with??... 2.. AND my wallet was lighter from the purchase!!! What is wrong with these people? Why can't they sell me a piece of balsa with a mass less than that of a bowling ball?!! And why the heck do they charge $100,000 per femtometer?!!!! I've had it with these people!
My Feedback: (18)
GA
RE: Fresh Aire
I don't know..I havn't ordered any yet but need to soon to skin some wings...
I've read more than one person say "Sig is the ONLY place to get contest balsa" :
http://www.sigmfg.com/cgi-bin/dpsmar...FV4.html?E+Sig
Then I've heard others mention these sites:
http://www.nationalbalsa.com/balsa.htm
http://www.dbalsa.com/
http://www.balsausa.com/
http://www.specializedbalsa.com/
From what I understand with most of those suppliers you need to specify you want lightweight contest balsa and there may be an additional fee??
I think I''ll probably try Sig...
Have Fun...
Chuck
Have Fun...
Chuck
My Feedback: (8)
RE: Fresh Aire
Nathan, enjoy your build and thanks for posting your work. As you know there are too many "legends in their own mind" type guys around here who are going to poo-poo whatever you post because they have a better way. Funny, but I don''t recall ever seeing their names as current/ or former Champions so their titles of "expert" must have been self proclaimed. Heck, if you want to cut out pineapple and banana shapes into your wings to save weight, go for it. It''s your plane. Lots of us like to see different ideas and techniques. It''s called learning and some guys seem unwilling to accept any possibility that there COULD be another way to do things other than "their" way. Thanks again for posting your work. Many of us do appreciate it.
PS- This is not directed at anyone personally, more of a general observation
My Feedback: (121)
RE: Fresh Aire
I''d recommed Lonestar, but they incinerated (literally). Hopefully, they will be back in business if they aren''t already. I''ve bought a few hundred dollars worth of contest balsa from them and been happy with all of it. I''ve also used SIG balsa and never been disappointed. Some of the LHSs that I''ve patronized over the years have stocked SIG balsa and I''ve found it to be very convenient on occasion. My dad has purchased quite a bit of wood from Balsa USA. He buys more than required and picks the best of what he gets (I''m not convinced that his method is very cost effective). I''ve heard good things about the quality of wood available from Nationalbalsa.
-Will
-Will
RE: Fresh Aire
Well, not as much progress as I''d hoped. We actually had nice weather this Sunday, so I maidened my Christmas present. It''s a beautiful airplane and has dead neutral static and dynamic stability with the CG moved aft a bit, so it''s a pleasure to fly and has plenty of power.
I also began the process of tracing my former onto some light ply. The only aircraft grade ply former will be the firewall. I couldn''t start cutting because my band saw blade needs replacement, so I''ll have to wait until tomorrow.
RE: Fresh Aire
i''m building by blue angel with wood ordered from nationalbalsa.com . i literally used the materials list that 8178 listed and my price was 2/3rd''s of his cost. so far i have found a couple of heavier pieces that i will discard or ask for a replacement sometime and one piece is warped. so i don''t know if that''s a bad track record out of a $100 order of wood. i will use them again, but i might specify contest grade, which will cost more of course.
david
david
RE: Fresh Aire
ORIGINAL: dhal22
i''''m building by blue angel with wood ordered from nationalbalsa.com . i literally used the materials list that 8178 listed and my price was 2/3rd''''s of his cost. so far i have found a couple of heavier pieces that i will discard or ask for a replacement sometime and one piece is warped. so i don''''t know if that''''s a bad track record out of a $100 order of wood. i will use them again, but i might specify contest grade, which will cost more of course.
david
david
RE: Fresh Aire
It also fits nice and snug. I love it when that happens.
Note: It isn''t exactly in position in this picture, so don''t worry about it. I didn''t have the plans out to check the exact angle.
RE: Fresh Aire
Fresh Aire
Nathan,
I know you will not forget to trim the edges of the fiberglass opening to about 5/16 of an inch. You will save a tiney amount of weight and reduce the wear and tear on your hands.
Rusty
Nathan,
Rusty
RE: Fresh Aire
ORIGINAL: BERUSTY
Fresh Aire
Nathan,
Rusty
Fresh Aire
Nathan,
Rusty
RE: Fresh Aire
Well, bad news. At the field yesterday I witnessed one of the original 12 Fresh Aire kits go down. The pilot lost all elevator control and the airplane dove straight down - the airframe is a total loss. He was still using original servos, so I'd bet the servo just failed after all these years of heavy flight loads.
Anyway, I would like to pose a question here. What do you guys think about electrifying this airframe?
