Slik-Fly By Phil Kraft.
Old 08-19-2010 | 02:16 AM
bem
Default RE: Slik-Fly By Phil Kraft.
Hi,
Does anyone have the RCM&ENovember 1969 construction article of Slik-Fli and can post it here? As JPG pages or as a PDF file.
Thanks.
/Bo
Old 08-19-2010 | 04:24 AM
Johnkpap's Avatar
Yes I have a copy,I
just need to pull it from my Archive of Mag's and scan it Will post ASAP
Johnkpap
Old 08-19-2010 | 04:49 AM
Johnkpap's Avatar
Here it is From a clean copy hot off the Scanner
Johnkpap
Also....My copy is very clean I will have ago at Scanning the plan bit at a high Res
I will post it if it is usable
File Type: pdf
Old 08-19-2010 | 05:29 AM
bem
Excellent Johnkpap!
Now we have plans source and the construction article covered in this threadfor those that want to build this nice airplane again.
/Bo
Old 08-19-2010 | 05:37 AM
From: Bishop\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'s Stortford,
What would we do without the brilliant guys here. Fantastic work and may many more of Phil's aircraft take to the sky.
Old 08-19-2010 | 07:00 AM
  #31
Johnkpap's Avatar
I have Scaled up the plan
Should be usable......
Let me know if it is ok.....If not I will have another try
Johnkpap
File Type: pdf
Old 08-19-2010 | 07:19 PM
  #32
Brilliant
Old 11-09-2011 | 04:04 PM
  #33
Youl'l find my slik-fly build here but no changes and with flaps and with a 61 its not going to hang around !
http://www.modelflying.co.uk/forums/...p?th=56039&p=1
Old 11-24-2011 | 07:53 AM
  #34
kdc
If you want to buy the plans note that XList plans are now part of MyHobbyStores.co.uk publishers of RCME etc There is a link on the site above with the SlikFli build.
