vintage pattern routine?
I would like to know if any routines exist from the mid 70's. I know its a weird question, but in October our club is changing its flying site name to honor an individual(Arthur Brock), and make an event out of it. I happen to own own of his vintage pattern ships(Miss Norway). The plan is to have him spot me while if fly the airplane, and I'd like to do something special, and fly a pattern routine from that era. By the way this will be my first time attempting to fly a "routine" so nothing in the masters class
Well The patterns for the vintage contest that were holding at my club feild in November is the following for novice.
1. Take off
Stright downwind trim pass
2.Stright flight out.
3.Procedure turn
4.Stright flight back
5.3 inside loops
6.1 horizonal roll
7.immelman turn
8.Stall turn
9.Landing
Not to hard if you can even fly at all, the 3 inside loops to make them loop just the same is the hardest to me. to do them perfect.
if this is not what your looking for sorry for crowding up the thread.
1. Take off
3.Procedure turn
5.3 inside loops
6.1 horizonal roll
7.immelman turn
8.Stall turn
9.Landing
ORIGINAL: MetallicaJunkie
My Feedback: (24)
NY
This is the current VRCS pattern sequence, I developed it for the VRCS about 5 or 6 years ago from sequences in the AMA rulebooks from 1966-1970.
CLASS III
1 Takeoff
2 Stall Turn
3 Three inside loops
4 Three axial rolls
5 Immelman turn
6 Reverse Cuban 8
7 Rolling 8
8 Inverted pass
9 One outside loop
10 Split "S"
11 Three turn spin
12 Touch and go
13 Landing Pattern
14 Landing
CLASS III
1 Takeoff
2 Stall Turn
4 Three axial rolls
5 Immelman turn
6 Reverse Cuban 8
7 Rolling 8
8 Inverted pass
9 One outside loop
10 Split "S"
11 Three turn spin
12 Touch and go
13 Landing Pattern
14 Landing
IN
If you go to www.seniorpattern.com all the manuvers in the 3 classes are 1975 or older.
thanks, i finallly found it http://www.seniorpattern.com/pdf/exspnov.pdf
edit* im just not sure about how to do these maneuvers, FIGURE M, RUNNING EIGHT,COBRA ROLL-FULL ROLLS
Look on the SPA site and it shows you how to do each one.
look where it says improve your flying skills.
http://www.seniorpattern.com/improve/
