PD06 Pump (OS 140RX) as a Hanno (PD05) substitute??
My Feedback: (18)
GA
Does anyone have any experience with the OS 140RX ?? I wonder if the pump would be a viable substitute for a Hanno pump?? I don't need one or anything but was thinking "just in case"...he he
Chuck
Chuck
RE: PD06 Pump (OS 140RX) as a Hanno (PD05) substitute??
Atlanta 60, I have an OS 140 RX pump with backplate that has not been used in years if you are interested. These pumps are/were very reliable. I ran a couple of OS 140 RX's & thought at the time I needed to "move-up" to a 4 stroke. Let me know if this is the direction you want to go in. It has been in the box ever since. Regards_____TNWalker
My Feedback: (18)
GA
ORIGINAL: TNWalker
Chuck
My Feedback: (67)
CA
Funny you should mention the pump thing. I was looking at the pump on my 70 Ultimate, as well as the pumps on the OS heli motors. Will need to do some homework here but it would be a payoff if one of those models worked.
My Feedback: (18)
GA
I've only heard of one or two Hanno pump's being bad...Apparently one sign of a busted diaphragm is fuel seeping from the pump "calibration" screw...
As far as I know all my pumps seem to be working but none have actually flown yet... [:@]
I would just love to have an alternate in the event one is INOP...
The 140RX pump seemd kinda kewl because it looks like it would fit in the backplate just like the origional PD05..
I think I've seen someone suggest you could use a Perry pump which I suppose if I were in a pinch would be OK...I just like the "self contained" unit a little better...
i bought a couple of k&b ducted fan engines just to get the engine running urges satisfied. something in my collection needs to run.
