Completed Daddy Rabbit
Old 05-20-2009 | 08:50 PM
My Feedback: (-1)
Default Completed Daddy Rabbit
At last it's ready for the maiden day. Engine is the SK .90, Futaba RX with Hitec 5475s and 475 servos. Iused a Hitec HS 80 on throttle and the HS 81 for the front steering control slaved to the rudder. It came in at 7 3/4 pounds, as heavy as that sounds I was expecting about another pound. It isn't an ARF!!!
ID:	1202711   Click image for larger version
ID:	1202712   Click image for larger version
ID:	1202713   Click image for larger version
Old 05-20-2009 | 10:37 PM
My Feedback: (18)
Default RE: Completed Daddy Rabbit
Fantastic!! Congratulations on the new bird...I hope you enjoy her...
Old 05-20-2009 | 11:15 PM
My Feedback: (27)
Great looking plane. Congrats!
Old 05-20-2009 | 11:35 PM
Aurora_60's Avatar
beautiful!!</p>
keep us informed on the maiden!</p>
</p>
DM</p>
Old 05-21-2009 | 12:13 AM
My Feedback: (27)
Hay Guys. Do you think that I may fly this plane of mine in SPA pattern events? It's old enough. Some of you may know of it. It's called Das Little Stik. LOL. Check out my little plane that now has an OS 46 AX pulling around 7.25 lbs. on a 4 lb. plane with only a 49 in. wing. Yea it's fun and nerve racking at the same time. I had the first one of these back when I had my Mach One. Thought you guys would get a kick out of this.
Terry
ID:	1202839   Click image for larger version
Old 05-21-2009 | 05:10 AM
Old 05-21-2009 | 03:21 PM
My Feedback: (121)
Hey Terry,</p>
   Looks like a lot of fun. I built a Das Little Stik back in 1973 and powered it with an OS 40 - a great fun-fly airplane. I'll bet your's is a real rocket - thankfully we have a throttle stick ...</p>
-Will</p>
Old 05-21-2009 | 03:42 PM
My Feedback: (27)
Believe me that's exactly where my left thumb stays. I'm getting out of this motor 15k on an 11 x 5 APC. That's a bunch better than my old K &amp; B 40 I use to have on my first Litl Stik. I'm actually thinking about using this engine on a ARF small modern pattern plane or finish the Bob Cat and put this motor in it. Thanks for looking.
Terry
Old 05-21-2009 | 06:13 PM
I see that the Daddy Rabbit looks agood bitlike a Taurus with a larger tail and a bit shorter fuse. Nice Plane</p>
