Phil Kraft's "Flea Fli"
#76
RE: Phil Kraft's
Summerwind
You should be fine with the amount of play you have in the engine sounds normal, make sure you use lots of Caster oil in your fuel.
Enjoy your Nice Engine
Johnkpap
Johnkpap
#77
RE: Phil Kraft's
OK, time to get serious since i have had a lot of PM's to do the kit.
i'm sourcing the parts to be laser cut and of course the pricing. i am also thinking i can jig these parts as there aren't a lot of pieces to hand cut.
a little about me though, i am a journeyman millman by trade..........not a typical kitchen cabinet builder, but a case builder of high end casework known as Premium grade as specified in the Woodwork Institution of California (WIC).......we build from raw stock.......you know, jointed,planed and cut to exact size.
here too is a scale thread i have going to show you what kind of a builder i am
http://www.rcuniverse.com/forum/m_8507751/tm.htm
#78
My Feedback: (21)
RE: Phil Kraft's
That is beautiful workmanship Mike andI would have guessed nothing less. I bet the FF's will create loads of smiles while being built. Looking forward to em so please keep up the work.
Mark
Mark
#79
My Feedback: (12)
RE: Phil Kraft's
Hi Guys,
Mike is a good friend, and I have been building for over 35 years! But I can always learn more from him! Mikes workmanship is unreal And to top it off most Scale builders do not fly that well, but let me tell you Mike
Flys unreal! Makes the wings melt in flight!! If Mike is doing a kit it will be right on the money. Now back to building any thing that flys [&:]
Joe Pierson
Kerman Ca.
USA
Joe Pierson
Kerman Ca.
USA
#80
RE: Phil Kraft's
Gotta question for the kit builders. Many kits require bonding 1/32 plywood to balsa for the fuslage side. I use titebond mostly and find that for this appliction it causes the balse to curl even when clamped between two 3/4 inch pieces of hard plywood. solutions?
#81
RE: Phil Kraft's
ORIGINAL: YellowBlueBird
my other method which is easier for sanding is to use Duco cement...........spread it, lay the 2 parts together and then use a second coat of glue and then press and weight the parts together. it's strong, and light.
another thing about Titebond that recently put me off was when building my WW1 planes that use Reed outlines and balsa was while sanding, the pieces did not hold together like i thought they would.
if anything i find Titebond dries too quickly to be absorbed into the wood enough to make a strong joint...........and i use to be a glue dobber to no end.
CA is all i use now, but for some people, CA causes problems.
Duco cement is great stuff, but has the acetone odor, so one or the other seems to be a trade off...........there i went on long enough
#82
QC, CANADA
RE: Phil Kraft's
Another idea. David.
#83
RE: Phil Kraft's
Because of this thread, I pulled out my FF plans and started "think building" this little cutie. But alast, I have other projects before this one. Who knows, that may change next month! I'd really like to see a build thread started on this model though!
FB
FB
#84
RE: Phil Kraft's
Yellowbluebird, I have always used contact adhesive for bonding ply doublers to fuselage sides. I have used Evostik and Dunlop thixofix (UK). I have built many models since the early '60's and have never had a failure. Two downfalls are, the smell and the need to be extremely accurate..you don't get a second chance as the bond is almost instant!
Free Bird..Likewise regarding a FF but it will be project 3 on the list although I have been sorting out various servos etc.
All the Best...Chris UK.
#85
RE: Phil Kraft's
Is Duco the same as SigMent that comes from Sig? The thinned epoxy and thick CA sound good. I fear that being a true southerner I am to slow to use the contact cement. Thanks for all the ideas. The FF plans printed out very nice. It will be a toss up as to whether the next plane after the Primus will be a FF or King Altair. The climbing price of glofuel may help make that decision. I have a family member that has offered to show me how to trace the pdf file to a program that will run on a local cnc machine. Right now I had rather build when time is available.
Another thought, has anyone considered a FF-10? That should be allmost perfect for the OS15 which might be just a touch light for this plane. Afterall one of our often contributers signatures his notes "Excessive power is just about right."
#86
RE: Phil Kraft's
Just thought I'd throw this in. On that site where all things are possible, is a NIB Midwest Flea Fly +10 kit. Price is up to $180 and there's still 11 hours left. Anyone care to guess how high this one will go? Kit prices lately have gone crazy!
FB
FB
#87
RE: Phil Kraft's
FB
FB
FB
#88
QC, CANADA
RE: Phil Kraft's
I don't get it. I mean, in as much as Kraft had a nice design for the time, this is a box and single rib planform bird. One could probably kit this within a day at home.
Then again, I know I paid astronomical prices for what can be chalked up to cool Japanese band sawn blocks courtesy of Mr. Kato...
David.
David.
#89
RE: Phil Kraft's
ORIGINAL: Free Bird
You guys aren't going to believe this, but the kit sold for a whopping $363!!![X(][X(] Unbelieveable what someone will pay for a kit!
FB
FB
FB
FB
just kidding, it's gonna get built and powered by the ST X25.
#92
QC, CANADA
RE: Phil Kraft's
Thanks Mike. Just doing a little back of the envelope.
For a nice wing loading of 16 oz/sq ft for either the FF or the FF+10 we should have:
FF:
Area: 270 sq in = 1.875 sq ft (the plan actually shows a little more - I measure the chord to 7.38" and the wing without tips is ~37.5" = ~277 sq in)
Loading: 16 oz/sq ft
AUW: (16 * 1.875) = 30.0 oz
FF+10:
Area: 336 sq in = 2.333 sq ft
AUW: (16 * 2.333) = 37.3 oz
They probably would both fly nicely at 32 oz (2.0 lb) and 40 oz (2.5 lb) AUW, respectively. The weights provided in the specs are a tad on the heavy side for models of this size (at least for today's standards).
How's the kit coming along Mike?
David.
FF:
FF+10:
David.
#93
RE: Phil Kraft's
FleaFli kit sold for $363!!!
Who would pay that ???
I have just about finished my own kit .....No box
Offers Please ....
Kit collecting has gone abit MAD[X(][X(]
Offers Please ....
#94
RE: Phil Kraft's
I have finished Cutting my Kit,
I will be building it over Christmas/ New Year ( We get alot of public holidays > Down Under )
Santa has also Delivered a present Early .......A nice ENYA 19 VI TV New in its box with Muffler
Just the thing for powering the Flea Fly > My HB 25 was a bit too hot and Heavy for this plane, I want to be able to land it and not rip its wings off
The Enya 19 is also a bit Shorter being bronze bushed and fits alot better as per the plan.
I will post more later
Johnkpap
Johnkpap
#98
QC, CANADA
RE: Phil Kraft's
Keep up the good work John.
Eventually I'll build mine but I'd rather wait for Mike's kit to come to fruition first. Any news Mike?
I've got two to three 25 sized projects lined up for building this winter - more than I can chew!
David.
David.
#99
RE: Phil Kraft's
Put the basic wing structure togeather today
The only part I have been unable to Source are the big horns for the allerons, I will have to cut them out of some plastic
or something :- any Ideas ?
Everything was real easy to build the only hassle was joining the wing halfs with the wire for the allerons, you can't put it in after they are joined lucky for me I did not screw this up
next is sheet the wing and cut out the allerons.
Johnkpap
Johnkpap
